Forum: Vue
Subject: Anybody using Modo's ImageSynth?
Izaro opened this issue on May 20, 2009 · 13 posts
Izaro posted Wed, 20 May 2009 at 8:28 AM
 I am trying to create a thatch material for a villa in Senegal: Despite much searching I have not found a seamless thatch material that is even close to real thatch.
However, the answer would appear to lie with Modo's ImageSynth...........is anybody using it, and if so, how are you finding the process & results, please?
Kind regards
GKDantas posted Wed, 20 May 2009 at 8:44 AM
Very easy to use and great results. I created some brushes for Carrara using it.
Follow me at euQfiz Digital
offrench posted Wed, 20 May 2009 at 9:15 AM
I used it too with great results. Now using version 2.
Be aware, though that ImageSynth works better when used on certain types of textures. It may be very good to make tileable pebble textures, but a bit tougher to use if you need semi regular structures.
Also note that base images with strong lighting differences (incident lighting) are almost impossible to use.
Fantasy pictures, free 3d models, 3d tutorials and seamless textures on Virtual Lands.
Izaro posted Wed, 20 May 2009 at 9:21 AM
 Good to hear: Thank you both for your feedback.
All the best
bruno021 posted Wed, 20 May 2009 at 9:30 AM
Never been able to get anything decent out of Image Synth, lol!
I bought PixPlant and for what I want (tileable textures out of my photos), it's perfect and soooo easy!
JCD posted Wed, 20 May 2009 at 9:31 AM
X3 - I use ImageSynth to create pretty much all of my tiling Vue materials and it's worth every penny. It's true that it works better with certain materials, but once you get the hang of what it will do and not do, working around those limitations in Photoshop isn't hard. i.e. ImageSynth will get you the tiling edges that are otherwise hard to create, but you can go back in and fix the bulk of the tile to your liking - at least this is what I do on the more complicated textures.
Monsoon posted Wed, 20 May 2009 at 9:57 AM
I use it too all the time. Great for noisy materials ie, gravel, dirt, etc.
Izaro posted Wed, 20 May 2009 at 10:05 AM
PixPlant looks ideal for my purposes (since it will also create the various maps for a full texture), but then I found out that it is Windows only & I'm on a Mac.............ho, hum......
Besides, both these software options are a rather expensive solution to creating one, possibly two,  seamless texture(s)!...........Might I be able to persuade one of you gentlemen to kindly work the necessary magic on two thatch photos in order to make them seamless, please?
Kind regards,
Patrice
bruno021 posted Wed, 20 May 2009 at 10:21 AM
Hmmm, would I let a fellow Frenchman down?
Though I can't do it now, have to go to work. I can do it for tomorrow, well try to do it...
Check your PM
Izaro posted Wed, 20 May 2009 at 10:58 AM
 Thank you, or rather, merci, Bruno...................I'll get an email off to you this evening.
GKDantas posted Wed, 20 May 2009 at 12:18 PM
I can do too if you need.
Izaro posted Wed, 20 May 2009 at 12:34 PM
 Thank you, GK, That is most kind: I feel spoilt for choice!
Izaro posted Thu, 21 May 2009 at 7:24 AM
 A very large thank you to bruno21 for creating two excellent seamless thatch images on my behalf.
Most appreciated
