sapa opened this issue on May 20, 2009 · 3 posts
sapa posted Wed, 20 May 2009 at 9:45 PM
out of memory
get this message when ever i do anything after the program opens.
i did the update did some funny things went back to cancel update
that's when this problem started I've uninstalled removed folders
cleaned registry I'm stuck like chuck so basically i can't use the program
and I'm slightly pissed! so Please help
also it say I have 90% resources
sapa posted Thu, 21 May 2009 at 8:40 AM
well e-on got back to and it seems i'm fixed
To do a clean uninstall, you don't have to mess with the registry. But you do have to delete a folder other than your applications folder.
Browse to the c:/Docments and Settings/username/ApplicationData/e-on software and delete the Vue 7 Infinite folder. This is a hidden directory so you need to have the option to view hidden files and folders turned on in your Windows Folder Options.
Then reinstall and you should be ok.
Rich_Potter posted Thu, 21 May 2009 at 12:37 PM
cheers for posting the fix!
