nyguy opened this issue on May 22, 2009 · 10 posts
nyguy posted Fri, 22 May 2009 at 9:23 AM
I am working on an interior scene. I have several parts to this, doors that opens and other movable parts. Now I am wonder if it is better to save it as a prop or as a figure or does it matter? I have it already saved as a figure.
Poserverse The New Home
for NYGUY's Freebies
EnglishBob posted Fri, 22 May 2009 at 9:49 AM
If there's rotation involved, you need it to be either a posable figure, or a series of parented props with their centre points adjusted accordingly so the hinges appear in the right place.
Sliding doors etc. which involve only linear motion can be done as a morphing prop.
nyguy posted Fri, 22 May 2009 at 1:27 PM
Quote - If there's rotation involved, you need it to be either a posable figure, or a series of parented props with their centre points adjusted accordingly so the hinges appear in the right place.
Actually this prop has a sliding door, and an elevator.
svdl posted Fri, 22 May 2009 at 2:40 PM
I'd suggest a posable figure (with bends off on the joints). Even though a morphing prop is possible, the posable figure is more versatile - for example, you could hide/show the elevator or door body parts as needed.
It might even be useful to designate the four walls and the ceiling as separate body parts - removable (hidable) walls are a great benefit for interior scenes.
That actually mirrors interior sets used in the television/film industry - retractable/removable wals for easy camera access.
JoEtzold posted Sat, 23 May 2009 at 2:41 PM
Also a posable figure can be deleted with one action where otherwise you have to delete all props each by each in case you will unload the scenery.
ockham posted Sun, 24 May 2009 at 5:14 PM
One more item in favor of a figure: you can apply pose files for motion and
materials directly to it. If you rig it as a prop, then the user will need to
have a figure somewhere in the scene before any pose files will work.
nomuse posted Mon, 15 June 2009 at 6:48 PM
Hacking the cr2 is useful here; you can set the scale dials to "hide," and make selected translate dials visible. With the dial re-named and limits set the end result can be quite elegant.
MistyLaraCarrara posted Wed, 17 June 2009 at 9:44 AM
Quote - I'd suggest a posable figure (with bends off on the joints). Even though a morphing prop is possible, the posable figure is more versatile - for example, you could hide/show the elevator or door body parts as needed.
Hi svdl, i was checking out your cool freebies. Does the spawn character script work on TY2?
(I had to make a morph to flatten her glutes for a mermaid tail I made for her.)
thanks. cheers - Lara
svdl posted Wed, 17 June 2009 at 2:18 PM
Quote - Does the spawn character script work on TY2
Sorry, it doesn't. It's geared towards figures that have PBM_CC and PBM_DC injection channels, and TY2 doesn't have those, AFAIK.
When I have the time, I'll make a version that'll work on figures without injection channels too.
MistyLaraCarrara posted Wed, 17 June 2009 at 2:27 PM
I was wondering what all those PBMCC were for, H3 has them all over the place.
After I save my H3 or A3 character to a full body morph,
can I delete those PBMCCs without breaking the character? Will it speed them up?
Thanks.
