melovewrestling opened this issue on May 28, 2009 · 10 posts
melovewrestling posted Thu, 28 May 2009 at 10:31 AM
Well, I've been thinking about creating a cartoon characters like the monster in Mortal Kombat.
My idea (which could be way wrong) is to put 2 models in the project, then "cut" the arms from one of them and set the new parent to the remaining model.
However I am not really good at "cutting" parts from a model. Anyone can give some insights?
Thanks in advance! :)
hborre posted Thu, 28 May 2009 at 11:36 AM Online Now!
A character with four arms does exist over at RuntimeDNA.
http://www.runtimedna.com/Bruizer.html
And there is a morph package available.
Latexluv posted Thu, 28 May 2009 at 5:44 PM
There once was a 4 armed Vicky 2 or 3. She's still in my runtime somewhere. I once had visions of doing a Shiva render. However, I don't believe anyone has done a 4 armed V4. Shame that.
Weapons of choice:
vagabondallen posted Thu, 28 May 2009 at 7:45 PM
vagabondallen posted Thu, 28 May 2009 at 7:50 PM
Miss Nancy posted Thu, 28 May 2009 at 10:10 PM
Victoria_468arms package was distrib. by numi et al. in 2002. he duplicated the arm joint sections in the cr2 file, then changed all instances of joint names, e.g. rShldr became r2Shldr in the second right arm. it's a rather tricky and time-consuming editing procedure, but it obviates the problem of a second hidden body.
melovewrestling posted Fri, 29 May 2009 at 5:22 AM
Thanks for the valuable input! :)
Yup hiding the remaining parts came to my mind but when I need to do some action pose, it doesn't seems to work effectively.
I like the idea of the "anatomically-correct" four-armed male approach! But I am not quite sure how to have it done.
Is there a way to .. hmm, say, "cut" the part above the chest of one character, and then "paste" it on top on the chest of other character? (wow in that case we can even make a 8 arms spiderman! :D)
and thanks for the link hborre, that character just look awesome!
Cheers
Tracesl posted Fri, 29 May 2009 at 9:16 AM
I think someone posted a way to do this here in the forums a while ago, going to have to search for it as I could not find the one I was looking for. It was for M3 but should work for M4.
Also, you may want to check out Free Spider Woman for V4 by AdamThwaites, it has six arms.
momodot posted Fri, 29 May 2009 at 9:54 AM
I tried to conceptualize a Posette 'space monkey' with a second set of arms in place of legs by parenting two figures together but I could never get it to work as something that made sense "anatomicaly" :(
Wild_Dog posted Mon, 08 June 2009 at 3:28 PM
Quote - Depending on how you plan to use it, in some cases you can simply hide all the parts except the arms. I've attached an example. I shrank the duplicate 5% as well for a better over/under shoulder fit.
well, that works a bit, but I decided to try some other ways. Your way works for a one behind the other arangement, but not so much for above and below types. I tried the above and below type, found that increasing the breast size of the female a tad bit worked.
Also, trying to do that anyway for V3- and Aiko3 dosnt work so well, so if you are trying to add arms, best to stick with P4 or V4/A4
