Subject: oh oh....runtimes folder gone...
stef1405 opened this issue on May 28, 2009 · 9 posts
stef1405 posted Thu, 28 May 2009 at 4:50 PM
hi @all,
Could please somebody help me?
i v e connected my card reader to my notebook and it has given my drives new letters.
i have told my poser pro that my poser pro content folder is on e: what now is named s:
it still exists on my extenal drive of course but as it now has a new name, poser pro says that the libraries cant be found...
ive uninstalled poser pro, then reinstalled it and still got that error.
Does somebody of u know where i can show my poser pro, where my poser pro content is to be found??
thank you
stef
IsaoShi posted Thu, 28 May 2009 at 5:16 PM
My suggestion would be to just edit your LibraryPrefs.xml file, changing the drive letter for your external runtime folder from E: to S: .
This file is in your user profile, in the same place as your Poser preferences (.ini) file. Look for the lines starting with <ContentFolder folder=.... and ending with  .....index="n" >
Don't change the index="0" or index="1" lines. Go to the index="2" line and change the drive letter you see there in the folder name. I can't show a real example because I'm on a Mac, and the paths are different, but it should look something like this:-
<ContentFolder folder="C:Program FilesPoser ProRuntimelibraries"  index="0" >
<ContentFolder folder="C:Program FilesPoser ProDownloadsRuntimelibraries"  index="1" >
<ContentFolder folder="E:3D LibrariesMain LibraryRuntimeLibraries"  index="2" >
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
IsaoShi posted Thu, 28 May 2009 at 5:20 PM
Alternatively... go into your computer Disk Management utility and change your card reader drives to W:, X:, Y: Z: , and your external drive back to drive E:
stef1405 posted Thu, 28 May 2009 at 9:07 PM
wow thank u for ur fast reply!!!
well, when i read ur solution, everthing sounded so good, but then...finally...hm, i didnt manage to find that file, it seems i dont have it...where can i find it?
is it poser "pro" u mean?
well in faCT WHEN I CHANGE THE LETTERS:::SURE BUT ITS A BIG CHANGE:::
oh i forgot: opening another ini, DefaultPoser.ini, it tells me, the pro content already is in s:, but poser doesnt find the library...strange
what does i have to do to make a clean reinstall? When i install poser again after uninstall, it doesnt even ask me for my serial....strange
oh dear...all i want is being able to pose again a s a p :(
byebye
stef
IsaoShi posted Fri, 29 May 2009 at 7:34 AM
Hmmm... of course it's your choice which way you want to try resolving this, so I'm following up on all three options here!
Changing your card reader drive letters is very straightforward. I always do it on all new PCs that have a built in card reader. You will then be able to use drive E: again for your content disk drive. This seems to me the easiest way forward.
The LibraryPrefs.xml file should be in your user profile. If you have Windows XP it should be something like:
C:Documents and SettingsApplication DataPoser ProPoser.ini
If you can't see a folder called Application Data, you need to tell Windows to show hidden files and folders. (Tools - Folder options - View - Show hidden files and folders).
To do a clean install, you need to delete the Program Files Poser Pro folder after uninstalling, and also the Poser Pro preferences folder in your profile (as mentioned above). Poser will re-create all of this from scratch when you re-install and run it.
stef1405 posted Fri, 29 May 2009 at 11:15 AM
fantastic...
i ll try the file search way...
right now..
stef
thx
IsaoShi posted Fri, 29 May 2009 at 11:21 AM
Hmmm... why does the forum always put the backslashes into Windows file paths when you first post them, only to remove them later? But I think you can see where they should be!
stef1405 posted Sat, 30 May 2009 at 3:06 PM
thank u soo much, i found the file though it actually is named differently.
searched for the ini and changed the letter drive with editor.
Everything works fine now, Thanks to your excellent tip!!!!!!!!!!!
Stef
IsaoShi posted Sat, 30 May 2009 at 3:52 PM
I'm happy you fixed it! I noticed I was getting confused with another thread in which we were talking about the .ini file -- sorry about that.
