Subject: Adding numbers, letters or symbols
camthaleon opened this issue on May 30, 2009 · 3 posts
camthaleon posted Sat, 30 May 2009 at 2:25 PM
In Poser 7, is there any way to easily add numbers or text on top of textures?
Also, if I want to make it look like there is a hole in the ground, it will leave the hole among the GROUND object, is there any easy way to cover the space around the hole?
hborre posted Sat, 30 May 2009 at 3:06 PM
I believe your are looking to decal within Poser as opposed to adding your number or text  to the original texture in a 2D program.  Here are 2 tutorial links on how to address it:
http://artzone.daz3d.com/wiki/doku.php/pub/tutorials/poser/poser-maps05
http://www.superheroinecentral.com/mrx/xpage/decaltutorial/decaltutorial.htm
Can't answer your second question, but some one more familiar with the process may elaborate.
pakled posted Sat, 30 May 2009 at 10:05 PM
you could use something like the Gimp (do a search on 'the gimp').  works like Photoshop, costs like sunshine...;)
You can save the picture, then import it into anything that can do layers.
