infinity10 opened this issue on May 31, 2009 · 8 posts
infinity10 posted Sun, 31 May 2009 at 3:38 AM Online Now!
You'll need to use your own stash of tech-type graphics.
The shader set-up is here:
HUD FX Poser 7 shader by ~ibr-remote on deviant[ART
I](http://www.deviantart.com) applied the shader to the Poser default Hi-res Square.
Eternal Hobbyist
infinity10 posted Sun, 31 May 2009 at 5:00 AM Online Now!
Eternal Hobbyist
pitklad posted Sun, 31 May 2009 at 5:21 AM
befanini posted Sun, 31 May 2009 at 7:43 AM
Those are awesome ^_^
Not to mention cheeky! "Thrifty Person" - I like that! ;D
chriscox posted Sun, 31 May 2009 at 11:17 AM
I personally don't like this set up. The hex pattern is plug into Diffuse node which means it will be affected by the lights and shadows in the scene. I would composite all my images together in Photoshop and then plug that image into the Alternate diffuse and transparency nodes. I would also add a blender node between the texture and transparency nodes to aid fine tuning of the texture's transparency.
hborre posted Sun, 31 May 2009 at 1:41 PM
I agree with you chriscox; the shader arrangement does look odd. Your solution seems much more logical.
infinity10 posted Sun, 31 May 2009 at 7:25 PM Online Now!
I understand your version, chriscox. That would have been the alternative - using an external graphics editor. I was trying to avoid that. But yes, the alternate diffuse node can also be used on its own for the HUD effect.
Eternal Hobbyist
infinity10 posted Mon, 01 June 2009 at 12:52 AM Online Now!
Re: notional Application example -
credit for the cylinder is D3D, not DDU.
Apologies.
Eternal Hobbyist
