Mannixman opened this issue on May 31, 2009 · 4 posts
Mannixman posted Sun, 31 May 2009 at 3:21 PM
I have a very elementary question for all you experienced 3Ders :
What do I have to look out for when modeling an obj for Studio?
My case: I'm modeling a little room in Blender 2.49.
I can get the geometry imported just fine into Studio.
But two things are missing: I don't have the ability to select say, a seperate wall even though it started as a seperate object in Blender (I want to be able to deselect walls for more camera freedom).
And I can't get all materials (only some) shown under the Studio surfaces tab and don't get the ability to mouse over the material zones too.
So I'm not totally hopeless but also not quite there yet :D
lyron posted Sun, 31 May 2009 at 3:30 PM
I think you have to export the elements of the scene that you want move separately not the whole scene. On the other hand if your objects have textures if you want export them in a obj file you have to use the UV mapping.
I hope these work.
Javier (Lyron)
RHaseltine posted Mon, 01 June 2009 at 11:45 AM
Yes, unless you have the Figure setup tools and use Skeleton Setup to make a figure a grouped OBJ file will be seen in DS as a single item, so your best option is to export each piece as a separate OBJ and then import them and parent them to a null in DS.
Mannixman posted Mon, 01 June 2009 at 4:23 PM
Thanks to both of you for helping me.
Now I understand.
I will consider the DAZ setup tools once I am better with my modeling ;-) .
