Forum: Vue
Subject: Possible To Add Glow To Planets?
Jonj1611 opened this issue on Jun 01, 2009 · 5 posts
Jonj1611 posted Mon, 01 June 2009 at 6:18 PM
Hi,
I am making a new scene with a planet in it(one of the ones that come with Vue), is it possible to add glow to these planets?
Or if not does anyone have any tips on how to get a nice looking planet into Vue?
I am using 7 Complete.
Cheers
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
Bijan_Studio posted Mon, 01 June 2009 at 6:58 PM
Select your object or planet and in material editor under "effects" tab check "Glowing material".
Bijan
Rutra posted Tue, 02 June 2009 at 12:07 AM
Using the normal "glowing" command on planetary size spheres is not a good idea. It's very, very difficult to control, almost impossible. This only works effectively in small spheres (a few meters radius). This may not be a problem to you if scale is not relevant (for example, if you're making a scene entirely in deep space, with no other references). But if the scale is relevant (for example, if the planet is seen from earth and you have montains, clouds, etc, to serve as reference), this will not work well.
I found it much better to simulate glow by duplicating the planet, enlarging it a bit (with the same center) and applying a volumetric material to it. This second sphere will be your atmosphere. You can use similar technique to make a cloud layer, for example.
There was a discussion about this in this forum, some months ago. Let me try to find it.
Rutra posted Tue, 02 June 2009 at 12:09 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3384342
Here.
Jonj1611 posted Tue, 02 June 2009 at 2:08 AM
Ah yeah I remember that thread vaguely now, ok cool, will have a read through it and see what I can come up with :)
Thanks again
Jon
