bagginsbill opened this issue on Jun 01, 2009 · 57 posts
bagginsbill posted Mon, 01 June 2009 at 6:42 PM
This is a 100% procedural cloud shader for my environment sphere, not a photo.
There are only two props here - my environment sphere and the Poser Ground plane.
It is a new all-time high for node count. It uses 744 nodes.
I implemented a volumetric ray-tracer entirely with nodes. There are two layers of clouds here. One at 15 to 20 thousand feet, and the other at 25 to 33 thousand feet. The atmospheric haze is such that it blocks half the view of the distant clouds at 60 miles away. These are distances you can't deal with using props. But there are no props at such distances here. The environment sphere radius is just 750 feet. The appearance of distant objects is all because the perspective simulated by the ray-tracer using the nodes, which seem to be able to handle huge numbers just fine, unlike the rest of Poser.
The water shader is not very good because the bump is just one node. I need to work out the math for an infinite series of distorted trochoids.
Anyway, I thought you'd like to see it.
Be sure to click for full size.
Acadia posted Mon, 01 June 2009 at 7:09 PM
Wow! That looks amazing!!! But it doesn't hold a candle to you candle shader which is still my most favoured one that you have made. Well, that and the glass globes :)
say." - Ghandi
hborre posted Mon, 01 June 2009 at 7:21 PM
THAT IS INCREDIBLE!!!! SIMPLY AMAZING! Definitely a must have for any serious shader fan.
But, wait a minute, isn't that Clover swimming in the distance?
infinity10 posted Mon, 01 June 2009 at 8:02 PM
lovely
744 nodes ? How do YOU keep track of them all....
Phew !
Water shader is going to be interesting as well.
The grand scale for Poser scenes, is finally at hand !
Eternal Hobbyist
lesbentley posted Mon, 01 June 2009 at 8:45 PM
I think it looks quite good. If I were going to be picky I would point out a couple of things. Too much yellow in the darker parts of the clouds. Perspective looks wrong near horizon, where clouds appear too small. Would also like to see an overall bigger cloud size.
DarkEdge posted Mon, 01 June 2009 at 8:51 PM
I'm seeing a pattern in the water and I agree with the clouds looking too small on the horizon line.
Not bitching just to bitch but that's what sticks out to me. Nice work.
bagginsbill posted Mon, 01 June 2009 at 9:10 PM
Here is with a 100mm lens.
Unfortunately, this reveals why I used the wide angle. I'm getting visible artifacts from my sampling of the clouds miles and miles away. If I reduce the sampling to fix that, I'll need a couple thousand nodes.
As for the yellow - there isn't any. The bottoms of the clouds are neutral light gray. The tops are a little bit blue, which would make the bottoms appear yellow. I thought the tops being lit a bit from the sky should be slightly bluer. Is that wrong?
Anyway - when I release this, the colors will be adjustable, as will cloud size, density, puffiness, and a bunch of other things.
MadameX posted Mon, 01 June 2009 at 9:40 PM
BB, will you ever out-do yourself?
This is incredible!
coldrake posted Tue, 02 June 2009 at 1:48 AM
No one is going to mistake the clouds for a photograph, but not bad. Good work.
Coldrake
shedofjoy posted Tue, 02 June 2009 at 3:52 AM
amazing, and an amazing volume of nodes too....
Getting old and still making "art" without soiling myself, now that's success.
ice-boy posted Tue, 02 June 2009 at 4:22 AM
700 nodes? rendertime is very long right?
you did this with matmatic right?
it will be interesting when you explain how you made them.
'' I implemented a volumetric ray-tracer entirely with nodes.''*
holly s..... thats insane
carodan posted Tue, 02 June 2009 at 6:22 AM
That is rather incredible.
Randomizing the cloud size more would greatly improve the realism I think, although one of the biggest problems with an overall procedural technique like this is really being able to predict what will appear and where. What I mean is, when I'm taking a photo or composing a painting I look for specific shapes that will lead the eye around the image. In this case I might be looking for cloud formations that nicely "frame" key features in the fore or mid ground, or which particularly add a sense of depth by leading the eye into the distance.
This is difficult with procedurals, unless you can define specific areas in which the effect will take place.
In Vue (when I had it running in V5) I could place specific cloud objects (cuboids whose final rendered formations would be procedural) where I needed them, and had more random and lighter higher level cloud formations as a general backdrop to these. Might be a direction worth considering.
I'm very impressed though - yes, render time(?)
PoserPro2014(Sr4), Win7 x64, display units set to inches.
www.danielroseartnew.weebly.com
Synpainter posted Tue, 02 June 2009 at 6:54 AM
BB,
Every time I read one of your posts I am astonished!
I would like to have .01% of your ability to come up with stuff.
:::Bookmarked:::
BTW, Thanks for sharing all your talent and abilities.
bagginsbill posted Tue, 02 June 2009 at 7:41 AM
Quote - No one is going to mistake the clouds for a photograph, but not bad. Good work.
Coldrake
Oops. Silly me. I was very punchy when I wrote that from lack of sleep. (Not clouds work - real work kept me up late nights lately.)
Of course it's nowhere near photorealistic. I meant to say:
This is not a photo-based solution. One technique for cloud rendering is to take a photo of a cloud puff and use it to drive an algorithm that generates thousands of slightly morphed copies of it.
bagginsbill posted Tue, 02 June 2009 at 7:46 AM
Quote - 700 nodes? rendertime is very long right?
Yes, of course. Even if a human could keep track of all that, the material room becomes so slow with so many nodes that each change would make you wait several seconds.
I generate the nodes with matmatic. There are so many because Poser shaders do not have looping procedures with variables. So, matmatic does the looping, and for each iteration it generates a set of nodes. In this render, there were 30 iterations for each of the two layers, so 60 sampling layers. Each sampling layer requires 12 nodes - that's 720. The other 24 nodes are for some control parameters, color choosing, and a few basic coordinate transformations that feed into every iteration. So the shader really is only 36 nodes, but part of it is repeated so many times to get the volumetric sampling.
Render time is longer than a simple photo, but not nearly as long as ray-traced shadows on transmapped hair. These images rendered in about two minutes.
bagginsbill posted Tue, 02 June 2009 at 7:54 AM
Quote - That is rather incredible.
In Vue (when I had it running in V5) I could place specific cloud objects (cuboids whose final rendered formations would be procedural) where I needed them, and had more random and lighter higher level cloud formations as a general backdrop to these. Might be a direction worth considering.I'm very impressed though - yes, render time(?)
Gotcha. I've seen Vue's clouds - beautiful stuff - what I aspire to do although I doubt I can get it that good.
I'm still working out the principles of how this works. The interesting about it is that the sense of depth does not come from geometry, although the placement does. Meaning, if instead of a full 360 environment sphere, you used the shader on a simple rectangle, you could position it anywhere you want and that's where you'd see the clouds. By changing the algorithm to confine it to just one puff or some other desired shape, the individual rectangle can be dialed to produce something specific, and by positioning the rectangle in the scene, to put that in a specific place.
Note that positioning the prop would only control the viewing angle where the puff would appear. Its actual 3d look and it's apparent distance from the viewer would be from the shader. You could put the prop just 20 feet away from the camera, but the cloud would still appear to be a few miles away. Think of it as a little window into another world where there is a cloud perfectly framed by the window.
carodan posted Tue, 02 June 2009 at 8:23 AM
Can you create more dramatic lighting effects with this kind of setup (rim-lit clouds)?
In any case, I'm mightily impressed with the render time of just a few minutes with all those nodes.
santicor posted Tue, 02 June 2009 at 8:51 AM
In your most recent posted image ( with the artifacts problem)
you no longer can see the 3 or 4 tiny dark bits right at the point where the water meets the sky.
In the earlier posted images, i saw these and wondered if those tiny dark bits were supposed to be visible, i wondered what you were going for ...but i like the fact that they are missing in the most recent image
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
bagginsbill posted Tue, 02 June 2009 at 9:16 AM
Quote - In your most recent posted image ( with the artifacts problem)
you no longer can see the 3 or 4 tiny dark bits right at the point where the water meets the sky.In the earlier posted images, i saw these and wondered if those tiny dark bits were supposed to be visible, i wondered what you were going for ...but i like the fact that they are missing in the most recent image
Those dark bits are Poser reflection rendering artifacts. They are showing up on the ground plane where it touches the environment sphere. They are 750 feet from the camera and Poser has numerical accuracy problems with this combination of extreme overall distance, extreme close distance between reflected and reflecting surface, shallow camera angle, and the bump pattern distorting the normals to create the waves.
I think they are still there, but in the zoomed in view, they are outside our field of view.
I'll sort out the tweaks necessary to get rid of those before publishing. That's why this is a WIP!
bagginsbill posted Tue, 02 June 2009 at 9:21 AM
Quote - Can you create more dramatic lighting effects with this kind of setup (rim-lit clouds)?
I think so but it will be tricky as all getout. Right now I'm just trying to get the overall effect to work. I'm not happy with the cloud function itself. I did this with FractalSum because it is the fastest of them all, but it doesn't produce the kind of pattern I want. The cloud boundaries are very diffuse here, even though the FS node is set up to do 24 octaves of noise!
I'm experimenting with fBm. This node is 10 times slower, and cannot be used in 60 layers without serious performance problems, but it has a much nicer detailed pattern to it. But, to use it, I have to solve the sampling artifact problem. I need to get the number of sampling layers down from 30 to around 6 in order to use that node. Unfortunately, the more detailed the cloud is, the more sampling layers you need. With the fBm node in the same setup as I have here, I get much worse sampling artifacts even with 30 layers. But the pattern is much nicer.
Ultimately, I want the shader to pay attention to the main light position. You should be able to move your infinite light, and this will influence 3 things:
1) The clouds will be lit from the right direction. At the moment, they are always lit from directly above.
2) If you are looking at the "sun", there will be a hazy glow around the sun. If there clouds between you and the sun, or even nearby, they will light up in full HDR.
ice-boy posted Tue, 02 June 2009 at 9:24 AM
whait a minute. those clouds are lit with lights?
bagginsbill posted Tue, 02 June 2009 at 9:24 AM
Yep.
ice-boy posted Tue, 02 June 2009 at 9:29 AM
what?????????????????????
so this is not just an effect. you actually build 3d clouds that are lit by lights?
this just got 200 times more awesome.
bagginsbill posted Tue, 02 June 2009 at 10:23 AM
Well, those words don't quite capture it.
I build a 3D density field. Within that field, there is a lighting gradient. Remember there are no surfaces here at all. Everything is about scattering light within a medium of varying density. Light can reach into the cloud only so far, because it is scattered. Light arriving (directly) on one side of the cloud is stronger than on the other side. However, some of the light that arrives in the middle gets scattered to the edges, so the shadow side is not at all as dark as it would be if there was a real surface with opacity.
Also, when light reaches into the middle part of a cloud, but there is more cloud between you and that part, you have to decrease how much of that you actually see, because the light cannot scatter all the way back out.
I have not fully worked out all the math for this, nor am I happy with the density function itself at the moment, but I'm making progress.
Anthanasius posted Tue, 02 June 2009 at 11:21 AM
Look really realistic !!!
I'm thinking ... If you've created two layers for the clouds, may be you can create two layer for ... a skin for exemple ! I say that but i say nothing ...
santicor posted Tue, 02 June 2009 at 11:30 AM
*Well, those words don't quite capture it.
In other words you recreated nature inside of Poser
as water vapor becomes more dense in the sky, clouds are visible
nice
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
bagginsbill posted Tue, 02 June 2009 at 12:16 PM
Because this density pattern is more detailed, my sampling rate is too low. I have to find a way around that problem.
But I like these cloud shapes a lot better.
ice-boy posted Tue, 02 June 2009 at 12:27 PM
this is more realistic.
why is realism always slower? can god not give us a break?
bagginsbill posted Tue, 02 June 2009 at 12:32 PM
But ... to get this kind of detail, I had to increase the number of samples. Each point in the render required samples equivalent to a ray-tracing depth of 100. Imagine trying to get Poser to do that with the renderer, instead of the shader, going through 100 layers of transparency. Impossible.
I was able to make each ray with slightly fewer nodes - just 9 instead of 12. So this is 922 nodes. This reaches my limit of tolerance for load times - it took 25 seconds just to load the shader.
Render time was not too bad - about 4 minutes. But I have some ideas about how to change my sampling strategy, which will let me increase speed by a factor of 10. If I can get this under a minute, I'll be happy.
ice-boy posted Tue, 02 June 2009 at 12:38 PM
this looks even better.
a little to complicated to render in poser since the renderer is not fast enough( i guess).
but still very amazing what you did.
GeneralNutt posted Tue, 02 June 2009 at 10:47 PM
Amazing work yet again, but wouldn't expect less. Could this be used to generate smoke coming from a lower object too?
bagginsbill posted Tue, 02 June 2009 at 11:17 PM
Quote - Amazing work yet again, but wouldn't expect less. Could this be used to generate smoke coming from a lower object too?
I think it could. I'll have to think about that. I made a morphing smoke plume prop and shaders a couple years ago and posted it at RDNA, but the link to the zip file is gone. So I've lost that file.
Boo hoo.
Anyway, it wasn't as good as this is looking, so I'll think about how to do it better, the way I'm doing here with a ray-tracer built with nodes. The one I built before involved thousands of procedurally trans-mapped polygons and it sucked for rendering because Poser gets very upset trying to do dozens of layers of transparency.
bagginsbill posted Tue, 02 June 2009 at 11:20 PM
Here is the smoke plume thread, in case you want to see it. But the link to the file is gone.
http://www.runtimedna.com/forum/showthread.php?t=31335
R_Hatch posted Wed, 03 June 2009 at 3:07 AM
Absolutely amazing stuff, BB.
GeneralNutt posted Wed, 03 June 2009 at 3:48 AM
I remember reading that thread about the smoke at RDNA , and was wondering if that's how this started. When you did the fog on the ground I tried to make that into smoke with no success.
raven posted Wed, 03 June 2009 at 7:26 AM
I have the smokeplume.zip if you want it bb. It's approx 1.4mb.
bagginsbill posted Wed, 03 June 2009 at 7:43 AM
Thanks raven (and GeneralNutt, too, who also offered in PM).
I found it. I woke up this morning and I remembered where I posted it - on divshare.
This was before I made my own Google site. Now I don't have this problem anymore.
stewer posted Wed, 03 June 2009 at 8:40 AM
Very impressive.
JOELGLAINE posted Wed, 03 June 2009 at 9:20 AM
Wow, BB, that looks like the sky outside my window right now! That looks realistic to me!:laugh:
Any thoughts to a cloud plane? We have a ground plane, why not the other? Would any savings of time be from a smaller cloud plane with the slower fbm node on it? Does the area of the env sphere (in sq feet or poser units) affect render time?
Does the angle of the sphere of plane affect the view of the clouds, or is the effect independant of the angle of incidence?
This quite exciting stuff to my mind.
Is a procedural night sky with clouds, stars and a moon on the horizon? Or Am I shooting for the moon with this question? :laugh: If someone says you've got your head in the clouds, just nod and walk away smiling. :lol:
I cannot save the world. Only my little piece of it. If we all act
together, we can save the world.--Nelson Mandela
An inconsistent hobgoblin is
the fool of little minds
Taking "Just do it" to a whole new level!
bagginsbill posted Wed, 03 June 2009 at 10:44 AM
Using a plane for geometry instead of a sphere is no good because it doesn't reach all the way down to the horizon, even if its size is infinite. Using a sphere gets full coverage down to the horizon.
Mathematically, I'm actually implementing the clouds as a series of concentric spheres, not planes, because I'm applying the curvature of the earth to the simulation (yes, I really am). In my first post I was using an infinite plane, and that was producing bad results, because we were able to see clouds more than a thousand miles away. Depending on your altitude when you render with my latest setup, the farthest cloud you see is between 8 miles and 60 miles. Of course, at 60 miles, it's all haze, but they are there where they should be and at the right size because of perspective.
Moving the camera does affect the perspective a bit, but you are free to move the camera without too much problem up to about 400 feet from the center of the sphere. That's plenty of room for animation.
I already have a procedural star shader, also galaxies, nebulae, etc. The shaders can be combined quite easily. A better technique would be to set up two concentric environment spheres. The outer sphere would have clear sky, which could be day or night. The inner sphere would have the simulation. This would run a little slower, because there is a transmapping involved on the cloud layer, but it's only one layer as far as the renderer is concerned, even if it is simulating 100 layers. By layering the sky (or stars) and clouds in two spheres, you could put a moon prop between them. You could put a light source in the moon prop and the clouds will haze and light up near the moon.
You could also use multiple cloud spheres, for multiple layers of clouds (cirrus, stratus, etc). These layered spheres do not have to be at those actual distances. They just have to be nested by about 50 feet or more.
The possibilities are endless.
bagginsbill posted Wed, 03 June 2009 at 10:46 AM
B for Bagginsbill.
These movable clouds render really fast, because they don't need to go for miles, so I just used 10 samples, and they are always artifact free no matter where you put them.
bagginsbill posted Wed, 03 June 2009 at 10:52 AM
cherokee69 posted Wed, 03 June 2009 at 11:24 AM
When are we going to be able to play with this?
bagginsbill posted Wed, 03 June 2009 at 11:32 AM
Hopefully next week. I have a lot of real work to do this week and my daughter's high school garduation is this weekend, so i'm kinda busy.
I will post it when i figure out how to do fewer samples without artifacts.
bagginsbill posted Wed, 03 June 2009 at 11:33 AM
cherokee69 posted Wed, 03 June 2009 at 11:35 AM
Quote - Hopefully next week.
Looking forward to it.
ice-boy posted Wed, 03 June 2009 at 12:33 PM
Quote - Render with ray-traced blur shadows. Sloooooow as with any transmap in this situation. Took about 15 minutes.
now imagine that you could set a ''cloud'' light with DM shadows. it would give you some soft shadows and the render time would be faster.
we need this SM he he :)
JOELGLAINE posted Wed, 03 June 2009 at 1:36 PM
If we could meta-blob stuff like in Vue, these cloud props would really fly! Really impressive stuff,BB!
Out of curiosity, do you have a SUN prop? We can't see lights in Poser, but there must be some convincing work around. I'm sure of it.
Nesting the spheres is a clever idea, that would light up the moon. That sounds exciting. I can't wait to get my hands on it. I got tons of ideas to try out on it.
ice-boy posted Wed, 03 June 2009 at 1:40 PM
Quote - If we could meta-blob stuff like in Vue, these cloud props would really fly! Really impressive stuff,BB!
you want to render out the sun?
import a texture of the sun and add it on a prop. or on the ENV_sphere.
cherokee69 posted Wed, 10 June 2009 at 6:57 AM
How's the clouds coming along?
bagginsbill posted Wed, 10 June 2009 at 8:16 AM
No improvement, cherokee69. I tried a change in how I sampled, and while it got a little better, it was still full of parallel sampling lines visible near the horizon, i.e. how you'd normally see them.
I'm going to have to come up with a very different virtual geometry. The math is beyond what I can work out in my head. I need to get out pencil and paper and derive the equations I need and it will not be easy.
Last weekend was my daughter's high school graduation, so I didn't do that, and this week I have a pretty heavy work schedule.
I'll keep you posted.
cherokee69 posted Wed, 10 June 2009 at 8:28 AM
Quote - No improvement, cherokee69. I tried a change in how I sampled, and while it got a little better, it was still full of parallel sampling lines visible near the horizon, i.e. how you'd normally see them.
No problem. I know you'll figure it out when you have the time.
mylemonblue posted Sun, 11 April 2010 at 4:12 AM
:b_stunned:
I almost fell out of my chair reading this. One thing I thought absolutely could not be done in Poser was volumetric clouds of any kind in any way. I've always wanted to be able to do this in Poser. I'd love to have volumetric clouds for ground fog and the kinds of clouds that drift low over the trees in the high mountain forests on cold mornings.
:b_drool:
My brain is just a toy box filled with weird things
JOELGLAINE posted Sun, 11 April 2010 at 5:29 AM
Months later,BB, any equations worked out, or is this shelved for good?
NanetteTredoux posted Sun, 11 April 2010 at 8:40 AM
This is amazing. I am in awe.
Poser 11 Pro, Windows 10
