Subject: script for downsizing textures
aleks opened this issue on Jun 05, 2009 ยท 17 posts
aleks posted Fri, 05 June 2009 at 4:55 AM
heya! i'm looking for a automatic python script or something similar for following purposes: i need v4, v3, m4 and m3 as background figures in 3d max scenes. i can import them quite well in max, no problem in that and i can reduce the polygon count low enough to make them renderable in relatively large numbers. what slows things down are highres textures that are normally available on the market, most of them around 4k pixels.
is it possible to write a script (or is there one) that can reduce the resolution of textures to around 1000 pixels more or less automatically? ideally i hit the "rescale" button on python tab and it saves the loaded xyz.pz3 with lowres textures! :-D i need figures and clothes for v4 & co because i also use close-ups so it HAS to be them! ;-)
thanks in advance
