Forum: Carrara
Subject: C7pro render room preview window
Darcal opened this issue on Jun 05, 2009 ยท 4 posts
Darcal posted Fri, 05 June 2009 at 3:24 PM
I've a slight problem with C7pro. It was fine before but now when I position the camera in the assemble room then look at the preview in the render room the camera position is much higher. Therefore I have to reposition the camera in the assemble room so that it's much lower than I want and keep checking the preview until it's as it should be. Not sure why it's suddenly gone wrong as I haven't changed any settings.
I've noticed cameras in Carrara sometimes have a frame which is seperate to moving/rotating the camera if you know what I mean, but there's no frame on my camera because I started a new document and never altered it.
Any help would be much appreciated.
Cheers.
GKDantas posted Fri, 05 June 2009 at 3:55 PM
A printscreen can help...looks that you have 2 cameras in your scene.
Follow me at euQfiz Digital
Darcal posted Fri, 05 June 2009 at 4:32 PM
Oops, I've just worked out what the problem was. I only have one camera in my scene but the production frame (which I didn't know about until now) was too high. I hadn't moved it though as I didn't even know what it was before. Well now I know to display and check the production frame before rendering in future.
Thanks for the reply and sorry to answer my own question. :lol:
Here's my little scene anyway, after framing.
Cheers.
GKDantas posted Fri, 05 June 2009 at 7:16 PM
You can see some video tutorials at Carraralounge.com
