garyandcatherine opened this issue on Jun 06, 2009 · 9 posts
garyandcatherine posted Sat, 06 June 2009 at 11:50 PM
I am running V7xstr 7.4. Whenever I import a poser file it always asks me to locate poser on my computer. Everytime I do this it works fine until I quit the program and restart it. Then the whole process repeats. It never saves that information.
Also, in the preferences where I can change the orientation of my axis', I try to set "Y" axis as up and down and it always changes back all by itself when I quit and restart.
Anyone got a solution for this?
Vege-Mite posted Sun, 07 June 2009 at 1:28 AM
Hi Gary; this was a problem for me in Infinite, with the first release of 7.4. It was fixed and all I needed to do was re download the patch and install it., although I did uninstall the offending release/patch first. Could this be your problem in Xstream?
Adriaan Barel (a.k.a. Vege
Mite)
"Morality, like art, means drawing a line someplace." --
Oscar Wilde
garyandcatherine posted Sun, 07 June 2009 at 1:43 AM
I will try that. THanks so much for your insight. I'll get back to you on the results.
FrankT posted Sun, 07 June 2009 at 8:54 AM
The first release of 7.4 had a bug whereby none of the settings would stick. E-On fixed it in pretty short order - if you download the patch for 7.4 now it should work fine (does for me anyway)
impish posted Sun, 07 June 2009 at 10:32 AM
I had a similar problem awhile ago when running Vue on a Windows Vista PC. Running it in Administrator mode and then finding where Poser was fixed it for me as Vue could then store where Poser was. Don't know if thats your problem but it might be worth a try.
Jonj1611 posted Sun, 07 June 2009 at 11:10 AM
Problem exists in Complete too
DA Portfolio - http://jonj1611.daportfolio.com/
offrench posted Sun, 07 June 2009 at 4:05 PM
Another solution is to disable the UAC if you are running Vista (if not already done).
Fantasy pictures,
free 3d models, 3d tutorials
and
seamless textures on Virtual Lands.
FrankT posted Sun, 07 June 2009 at 4:35 PM
It happens on XP as well - it's not a permissions problem, there was a bug in the patch
garyandcatherine posted Sun, 07 June 2009 at 9:03 PM
Yay! I fixed it following vegemites advice. Uninstall then reinstall. Problem solved. Thx all for the help
