lior opened this issue on Jun 21, 2009 · 13 posts
lior posted Sun, 21 June 2009 at 4:11 PM
aquiavic posted Sun, 21 June 2009 at 4:49 PM
Well
I am subscibed, I'll be watching.
ArtPearl posted Sun, 21 June 2009 at 5:52 PM
Attached Link: Water editor & materials
You have to start with a water plane which has the meta water material. Then you edit the water object (double click in the wold browser, or object->edit in the top menu). You'll get the 'water surface options' window. first you can control the overall wave appearance by ticking the 'global wave control' box and moving the slider. Then un-tick the box, which will enable you to change the individual sliders in the 'waves' section. I attached the values I had in a recent experiment and part of the associated image. You can change more parameters in the function editor. You maybe interested also in the thread in the link above."I paint that which comes from the imagination or from dreams,
or from an unconscious drive. I photograph the things that I do not
wish to paint, the things which already have an
existence."
Man Ray, modernist painter
http://artpearl.redbubble.com/
lior posted Sun, 21 June 2009 at 6:23 PM
Thank you ArtPearl
Is it the same way with Vue7.5WinPLE?
Must I take default materia water for the beginning?
ArtPearl posted Sun, 21 June 2009 at 6:54 PM
If you didnt use the water editor before, starting with the default will be easiest. I dont think there is a difference in the water editor in v7.5 PLE, but I never used it so I maybe wrong. Just try it, you can always post more questioned if you encounter problems:)
existence."
lior posted Sun, 21 June 2009 at 7:01 PM
Quote - If you didnt use the water editor before, starting with the default will be easiest. I dont think there is a difference in the water editor in v7.5 PLE, but I never used it so I maybe wrong. Just try it, you can always post more questioned if you encounter problems:)
Thank you very much for the water editor I have to try
Joy and Happiness for you!
Lior
john5d posted Mon, 22 June 2009 at 12:26 PM
Someone sells the big waves at the store here:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=72196&keyword=wave
Rich_Potter posted Mon, 22 June 2009 at 12:38 PM
Attached Link: http://blog.richard-potter.co.uk/guides
here are some water editor guides I did which show you all the settings in the water editor and what each one changes etc. Might help you if you havent used the water editor before. :)lior posted Mon, 22 June 2009 at 2:56 PM
Quote - here are some water editor guides I did which show you all the settings in the water editor and what each one changes etc. Might help you if you havent used the water editor before. :)
Thank you very much for this tutorial and I tried with it=it's a real useful tutorial
But I haven't found the water settngs for www.renderosity.com/mod/gallery/index.php
Thank you for your support,
Lior
gillbrooks posted Tue, 23 June 2009 at 8:42 AM
Quote - > Quote - here are some water editor guides I did which show you all the settings in the water editor and what each one changes etc. Might help you if you havent used the water editor before. :)
But I haven't found the water settngs for www.renderosity.com/mod/gallery/index.phpThank you for your support,
Lior
He probably used a terrain with a water mat added for that scene. You could always site mail to ask. If anyone asks me how I did something I'll always tell them (assuming I can remember!!)
Gill
lior posted Tue, 23 June 2009 at 3:47 PM
Quote - > Quote - > Quote - here are some water editor guides I did which show you all the settings in the water editor and what each one changes etc. Might help you if you havent used the water editor before. :)
LiorHe probably used a terrain with a water mat added for that scene. You could always site mail to ask. If anyone asks me how I did something I'll always tell them (assuming I can remember!!)
Thank you very much Gill
Darboshanski posted Fri, 26 June 2009 at 9:16 AM
lior posted Fri, 26 June 2009 at 9:29 AM
Quote - Bijan has big waves for sale here in the Rendo marketplace for Vue.
I wonder how I could use this item 'cause there are .Vue files and I'm now working with the learning edition that's to say Vue7.5PLEWin=impossible to open .Vue files!
Thank you for your help,
Lior
