Forum: Blender
Subject: import V4 to make statue
blueblott opened this issue on Jun 22, 2009 · 13 posts
blueblott posted Mon, 22 June 2009 at 6:48 AM
**Hello again,
can some one offer a little advice please.
Am trying to import Victoria 4.1 from DazStudio into blender with the intention of making her
into a Marble statue.
Can bring her into Blender as a wav object ok but dont seem to be able to apply any textures to her?
Is there any way this can be done
Thanks very much for your help
Regards Blueblott
lyron posted Mon, 22 June 2009 at 6:59 AM
Try to do the same as .obj I think it works fine.
Javier
lisarichie posted Mon, 22 June 2009 at 8:21 AM
delete the eyelash meshes, you won't need them on a statue
delete all the materials that imported with V4, this is to provide a "clean slate"
create one new material, in edit mode select all the remaining V4 verts and click assign in the materials section of the links & materials tab
press the F5 key to enter the shading tab adjust any material properties here
press F6 to enter the texture area, this is where you assign textures to any texture channels you have created. At this point you can use the procedural  or load an image texture into the texture channel.
press F5 again and re-check your values to ensure the shading values are set to what you want and the Map Input is UV and the Map To is color
press 0 on the numberpad and suitably frame the statue in the view
Press F12, evaluate and make any needed adjustments to your material values
blueblott posted Mon, 22 June 2009 at 10:06 PM
**Thanks for your help,very much. Lisa and Lyron
Would you happen to know if it is possible to get a Bryce mesh/v4 into Blender ?
Thanks for help
Blueblott
lyron posted Mon, 22 June 2009 at 11:28 PM
I exported a terrain as .obj from Bryce 5.5 to Blender once but I had to add the texture in blender.
blueblott posted Tue, 23 June 2009 at 1:08 AM
Thanks pity it wont export with textures though Lyron !
Have made my marble Statue just great in Blender after importing from Daz thanks Lisa.
Blueblott
lisarichie posted Tue, 23 June 2009 at 11:48 AM
Well after all that I want to see!:laugh:
blueblott posted Thu, 25 June 2009 at 7:31 AM
** Hi Lisa,
sorry just read your last post here is a a pic of Victoria 4.1 imortalised in
green Marble lol .
Thanks again for your help.
Kindest Regards
Blueblott
lyron posted Thu, 25 June 2009 at 7:52 AM
Fantastic result. Great work!!
lisarichie posted Thu, 25 June 2009 at 8:57 AM
Thanks for salving my curiosity!:biggrin:
(Just to be perfectly clear I wasn't complaining I was teasing.)
blueblott posted Thu, 25 June 2009 at 8:59 PM
Thanks very much  Lyron and Lisar,
After all the help you have given me I was pleased to be able to let you see I was putting it to good use, or trying anyway!!
"I dont mind you being a tease but please keep the answers comming lol"
Thankyou both very much.
Blueblott
ysvry posted Sun, 28 June 2009 at 10:44 AM
looking great
for some free stuff i made
and for almost daily fotos
blueblott posted Mon, 29 June 2009 at 1:47 AM
***Thankyou Ysvry for looking and coment .
Regards Blueblott
