Subject: ERC not working with IK
midnight_stories opened this issue on Jun 22, 2009 · 12 posts
midnight_stories posted Mon, 22 June 2009 at 4:11 PM
All other forums have failed to answer this, so this is my last hope
I’m not sure if this is possible or if anyone can answer this. What I’ve done, is create ERC morphs for the thighs they work with a normal bend and side-side but when if you use IK it doesn’t work, is there another channel I can use to drive this that works with IK or am I wasting my time.
The only other option is drive the morph with the Y transition of the foot.
ockham posted Mon, 22 June 2009 at 4:28 PM
Without a picture it's a little hard to tell, but IK is definitely dominant.  If your
morph would move the legs in a way that you couldn't do "manually" when
IK is on, then it won't happen from the ERC either.
My python page
My ShareCG freebies
pjz99 posted Mon, 22 June 2009 at 4:42 PM
I haven't applied IK with joint controlled morphs, but I can tell you for sure that ERC and IK don't work all that politely together in other ways, it seems that Poser's IK is not "aware" of joint rotations that are obtained through ERC.
My Freebies
midnight_stories posted Mon, 22 June 2009 at 5:14 PM
Yes the more I think of it IK doesn’t drive any of the channels used in ERC. So maybe the answer is to make some transitional morphs to drive the leg movement and leave IK out of it. At least you guys understood the question the rest of the other forums didn’t understand the question Thanks for the help.
pjz99 posted Mon, 22 June 2009 at 6:13 PM
There are a lot of wierd applications for ERC, you can for example drive a joint rotation with a morph (a morph-controlled joint instead of a joint-controlled morph).  You may want to poke around in these documents:
http://www.nerd3d.com/modules.php?name=Content&pa=showpage&pid=8
http://www.rbtwhiz.com/rbtwhiz_ERC.html
http://www.kuroyumes-developmentzone.com/poser/poserfilespec/ucr2filespec_dec2004.pdf
My Freebies
lesbentley posted Mon, 22 June 2009 at 7:46 PM
A few more details of exactly what you ar trying to achive might help. I gather that you want to control the morphs from joint rotations, that is normally referred to as JMC (Joint Controled Morphs). Does this involve walk cycles?
I don't have any answers off the top of my head, but feel you may have more chance of success driving the morphs from Y transition of the feet.
midnight_stories posted Mon, 22 June 2009 at 8:54 PM
 Here's some shots one uses bend and the other IK
midnight_stories posted Mon, 22 June 2009 at 8:55 PM
this is the IK one no deform of the belly
pjz99 posted Mon, 22 June 2009 at 9:08 PM
What happens after you place the foot and THEN turn off IK?  Doesn't matter really I suppose because it's not doing what you want, but I'm curious if the joint will get dialed up as soon as IK is disabled (I suspect it will).
My Freebies
midnight_stories posted Mon, 22 June 2009 at 9:27 PM
 Yes it does work if you turn off IK and pull the foot around. I tried linking the morph to the foot y Transition but nothing happened at all. Hey thanks for the links some intresting reading!
odf posted Wed, 24 June 2009 at 6:39 AM
Funny, I noticed the same thing a few days ago. Posing with IK doesn't trigger the JCMs, but as soon as I turn IK off again, they're back.
Diogenes posted Wed, 24 June 2009 at 11:22 AM
I have found that if you set up the animation cycle with IK on and then just turn off the IK for the actual animation it works OK, extra work. :)  Maybe this is a good argument for magnets and body handles. Also the morph controlled joints is an interesting concept but I have never checked it out yet.
Been messing with slaved body handles for the fat man I'm working on, to get the rolls of fat to move around when he walks. Using much the same idea that odf is using with the cascading JCM's in Antonia only with body handles instead of morphs. Ockham and Lesbently both had some interesting threads awhile back on this.
Hi ockham, how's it in Spokane? I'm a native washitonian from Okanogan WA.
cheers,
Mike.
A HOMELAND FOR POSER FINALLY
