eaglecop opened this issue on Apr 21, 2001 ยท 3 posts
eaglecop posted Sat, 21 April 2001 at 10:21 AM
sama1 posted Sat, 21 April 2001 at 12:26 PM
How about yTrans 0.015 for the "Hip" bodypart of the T-Shirt and the adjust the yScale down to 90%. Also you may need to adjust the "chest", "right collar" and "left collar" to about 95% yScale. These were just quick adjustments you may need to fine tune them to get the results you want. I hope this helps, Sam
hauksdottir posted Sun, 22 April 2001 at 12:31 AM
Ah, yes, the fun part of dressing our little people. There is a "taper" dial or you can scale the lower part of the shirt so that it will fit inside the jeans. If your guy's skin shows through (check a couple of poses), you can make invisible those parts of his body hidden by clothing. Remember that negative numbers work, too. Sometimes you are tapering plus or minus X degrees depending upon which part or side of the "figure" you are working with. Carolly
