Analog-X64 opened this issue on Jun 28, 2009 · 8 posts
Analog-X64 posted Sun, 28 June 2009 at 12:37 PM
tom271 posted Sun, 28 June 2009 at 2:33 PM
good for tincturing too.... These are fun and are printer ink guzzlers....
50parsecs posted Sun, 28 June 2009 at 3:15 PM
Thanks Analog! This would be very easy to map to an appropriately scaled cube. I'm sure one could use it for a mid-range background prop, or using the larger version, for a template and map, it would be relatively easy to build a well-detailed machine for a foreground render. "Pop" machines are ubiquitous the world over, and maybe even on Mars. I'll bet this could be useful for building a model in Bryce too.
BTW, do you know of any other similar "cut-outs"? They could be a valuable, reasource.
Thanks again,
RobertJ posted Sun, 28 June 2009 at 3:34 PM
Robert van der Veeke Basugasubasubasu Basugasubakuhaku Gasubakuhakuhaku!! "Better is the enemy of good enough." Dr. Mikoyan of the Mikoyan Gurevich Design Bureau.
Analog-X64 posted Sun, 28 June 2009 at 4:49 PM
Found some more stuff.
Photos of Vending Machines Follow the links to top right.
http://jihan.sblo.jp/
Nissan Japan: no need to read the text just grab the PDF files.
http://www.nissan.co.jp/EVENT/PAPERCRAFT/
Sponsored by Yamaha Japan: AMAZING is the word.
http://www.yamaha-motor.co.jp/entertainment/papercraft/
Canon Japan:
http://cp.c-ij.com/ja/contents/1006/
Some kind of Cartoon:
http://kuma0rila.blog120.fc2.com/
bobbystahr posted Sun, 28 June 2009 at 6:14 PM
Bear in mind that these are considered copyright violations in any free stuff item and I would also assume if used in a render as the focus they'd recieve a notice as well.. ...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Analog-X64 posted Sun, 28 June 2009 at 6:22 PM
I dont plan to render with them, I actually plan to print and make these things for fun.
bobbystahr posted Sun, 28 June 2009 at 6:56 PM
well I thought that but thought I'd put that out there fo anyone intending their use as a texture...those trains were awsome. I have a friend heading to Japan so I'm going to ask a favour of a few of those to build myself.. ...
Once
I see
a sound
and
Sometimes
