cujoe_da_man opened this issue on Jun 29, 2009 · 15 posts
cujoe_da_man posted Mon, 29 June 2009 at 11:48 AM
I recently grabbed a freebie car and wanted to do some custom texture work on it, but found that it has no UV map of any kind, is there a way to add one? I tried to use UV mapper, but while it can give me a map, I can't apply it to the car
BeyondVR posted Mon, 29 June 2009 at 11:56 AM
You have to resave the OBJ you mapped in UVM. The mapping wil apply to it, not the original OBJ. Hope this helps.
John
cujoe_da_man posted Mon, 29 June 2009 at 12:03 PM
hmm, still same problem... I noticed the model came with its own textures, but those don't seem to work either
LaurieA posted Mon, 29 June 2009 at 12:05 PM
Yes, you have to load the obj you want into UVMapper, make the mapping the way you want it and resave the obj. Of course if you resave over the original, the new prop will have your mapping. If you want separate material zones, you'll have to set them up as such, which I think can only be done in the pro version. I haven't checked tho, so I may be wrong. It's been a long time since I've used the free verson :o).
LaurieA posted Mon, 29 June 2009 at 12:07 PM
Quote - hmm, still same problem... I noticed the model came with its own textures, but those don't seem to work either
Then you saved over the original model. Your best bet (if you want to use both mappings) is to save the obj file you made the map for with a different name and import THAT into your program.
cujoe_da_man posted Mon, 29 June 2009 at 12:08 PM
I actually deleted everything and reloaded the original model, maybe poser just doesn't like this particular file, grr
LaurieA posted Mon, 29 June 2009 at 12:09 PM
If you lead me to the free prop, I'll check it out for you. Do you use Poser 7? I also have 6 installed on my machine and can check it there too.
cujoe_da_man posted Mon, 29 June 2009 at 12:12 PM
yep, poser 7
http://dmi.chez-alice.fr/models24.html
here's the link, the 2009 Camaro. maybe it's just not compatible with Poser, but I thought all UV mapping was universal for all programs, but this isn't the first time I've done this either, that's what has my stumped
LaurieA posted Mon, 29 June 2009 at 12:13 PM
Alright then :o).
I'll give it a looksee and let you know!
cujoe_da_man posted Mon, 29 June 2009 at 12:13 PM
awesome, thanks
LaurieA posted Mon, 29 June 2009 at 12:44 PM
What I'm finding so far (and I'm not done with it yet), is that most of this car has no textures. The material zones are there, but only some have an actual texture map.
As for UV Mapper, I can see the groups (which correspond to the materials), but I cannot assign them to a material because there are no uvs. I'm going to continue with it further - it's tricky because it's in French, so I have to translate the different parts...LOL.
I'm gonna keep at it for awhile :o)
cujoe_da_man posted Mon, 29 June 2009 at 12:46 PM
yeah, that's the problem I had, I could create a new UV file, bur for whatever reason I couldn't attach any actual textures to it. Even loading the original file in Poser and selecting the textures by hand, they only show up black
cujoe_da_man posted Mon, 29 June 2009 at 12:59 PM
ok, I think I have it figured out, it looks like it's treating the entire car as one big texture group and I'm trying to select certain parts only, guess I'll have to work around that
LaurieA posted Mon, 29 June 2009 at 1:08 PM
Quote - yeah, that's the problem I had, I could create a new UV file, bur for whatever reason I couldn't attach any actual textures to it. Even loading the original file in Poser and selecting the textures by hand, they only show up black
You're better off using Poser's shaders for most of the parts anyway. I'm still working on the other parts :o).
MistyLaraCarrara posted Tue, 30 June 2009 at 10:21 AM
I posted a few screen-shots of mapping a basic model in Wings3d.
In case it's helpful-
near the bottom of this thread:
www.renderosity.com/mod/forumpro/showthread.php
(www.renderosity.com/mod/forumpro/showthread.php?thread_id=2773536)
