lakota opened this issue on Jul 03, 2009 · 66 posts
lakota posted Fri, 03 July 2009 at 2:30 PM
First, I can't seem to create a "real" looking flame for the candle on the mantel. Second, the floor shadows do not seem right to me, especially under and around the table. I would think this area would be darker without the far legs of the table being illuminated greater then the forward legs, or the knee of the fat officer, who's knee is under the table and shouldn't be lit at all. Plus Vickie should have some shadows starting at her foot, I would think. In addition, the stool seems a bit bright.
Could the light of the lantern on the table be passing through the table but its shadows stopping on the table and if so why? Also the pz3 of this scene is over 207 MB, but excluding the "heavy morphs" of the seated Officer plus his pants, coat, and boots there isn't any custom geometry, except all the lights and shadow cam lights which seem to be all made of custom geometry, which I don't think should be in the file at all.
The Blockhouse interior is about 20 foot square with the ceiling at 10 feet. The front and left (right in frame) walls not being used in the scene. The table is in the center of the room with a lantern centered above it and another lantern on the table slightly forward. The left and right lanterns are parallel to each other about 4 feet forward of the center lantern all at the same height. The candle is there to illuminate the picture, which it doesn't seem to be doing well. The left lantern is there to illuminate the deck and flags. And the right lantern is there to add some light to Vickie while still keeping the m3 Soldier in the shadows with all lights.
I would like to get Vickie lit more without drastically effecting the m4 officers except adding a bit more bounce to the standing officer's hat, or adding any more light to the m3 Soldier expect maybe get some highlight going in the bayonet and shako plate and plumb on his hat.
The 5 light sources seen in the image are the only lights illuminating the scene. The fire light is created by a group of "Spot" lights circulating the cinders with a semi transparent cylinder of smoke to dampen their effects on the floor. The lantern lights are each created by 2 Point lights with the inter light set at 100% intensity, 0.0% shadow with a end point of 0.250 feet, and an outer light set at 70% intensity, 0.500% shadow with a start point of 0.300 feet and an end point of 11.250 feet. The each lanterns is turns slightly to make the forward glass perpendicular to the camera to keep the illusion of a flame, if not it just wigs out. The candle light is the same as the lanterns, but with out a "glass" panel in front of the light, I don't get the same effect.
ockham posted Fri, 03 July 2009 at 3:14 PM
I really like the atmosphere of this scene. Agree that the lanterns look just right
but the candle doesn't.... you could try adding yellow ambient to the flame prop
if it's not already there.
Shadows from point lights always behave weirdly. You could try moving the point lights
for the ceiling lanterns down below the lanterns; this would eliminate whatever
effect the body of the lantern might have, and would still look good (I think!)
lakota posted Fri, 03 July 2009 at 7:29 PM
Pulling the 70% intensity, 0.500 shadow "Point" lights down below the lanterns does warm up the scene, allow the intensity to be adjusted without wigging out the flame in the lantern, and does produce more realistic shadows on the floor.
However, on the down side it eliminates the intense flame in the lanterns I thought added to the scene and kind of removed the dapple lighting effect caused from those lights on the ceiling.
I guess the next attempt should be to add three more points of lights inside of each of the ceiling lanterns and try lowing the "Dist End" values to get the flame back but not cast light much farther past the lantern as possible.
The frustrating thing is that these Point lights don't illuminate anything in the preview mode and it takes several hours to render the scene before I know anything about the effects of any adjustments made to the lights.
Miss Nancy posted Fri, 03 July 2009 at 8:14 PM
just wanted to mention that we seldom see such a well-constructed scene here.
however, when setting the shadow dial on a poser light, as was probly noted above, any setting less than 1.0 allows lite to pass thru solid objects. setting shadow at 0.5 allows half the lite to pass thru. setting shadow dial to 0.0 allows all the lite to pass thru. some users suggest that this is a bug, as they feel that lite should not pass thru opaque objects, but it's actually a feature, not a bug.
lakota posted Fri, 03 July 2009 at 9:06 PM
Miss Nancy,
Well, thank you and thank you for the information. That is very helpful.
I'm a Painter, Cartographer, and Draftsmen and sometimes make 3D widgets. I don't really know Poser that well, except it has been a pain to use for me since version 1. I did not know that about the shadow settings and somehow always assumed it was the intensity of the shadow cast that the dial controlled, not its X-ray powers. Silly me! I always thought transparency of an object controlled its density or opaqueness.
Normally, I would just export the scene to a renderer and figure the lighting out in there just to avoid the frustration, but doing a complete scene in poser is the objective.
Anthanasius posted Sat, 04 July 2009 at 2:57 AM
You can also try the inverse square shader for the point light from Bagginsbill !
lakota posted Sat, 04 July 2009 at 4:13 AM
I don't know what that is, or were to find that.
I've read a few posts that mention "inverse square" posted by Bagginsbill
but at a great loss to understand what it is.
bagginsbill posted Sat, 04 July 2009 at 8:34 AM
It is the key to lighting an indoor scene.
Very briefly:
Luminance is like temperature - it has to do with the amount of light energy within a given area. As the light energy moves away from the source, it is always spreading out over a larger and larger area. Since the amount of energy is not changing, but the area is increasing, that light gets spread thinner and thinner, appearing weaker.
The math is simple. The luminance is inversely proportional to the square of the distance from the light. Do not say your head exploded. This is nonsense I hear all too often. If you are in a society where it is shameful to be able to understand a simple math formula with only 3 terms in it, then go hide under a blanket and READ THIS.
Let's say "d" is the distance between some prop and the light source.
d is distance
Let's say "I" is the intensity (strength) you choose for the light in Poser.
I is Intensity
Ready? The illumination from any light should be
I / (d^2)
That's I divided by d squared. Inverse square falloff.
It is neither difficult to understand, nor expensive to compute. It is an enormously obvious physical effect, and without it indoor lighting looks totally fake.
Yet, Poser lights do not implement this formula. We need not explain why such a fundamental fact of the universe was ignored in Poser, despite it being trivial to calculate. We need only find a way to add it to the calculation.
Thus was born my Inverse Square Falloff (ISF) light shader.
I don't know where it is at the moment, but I'm sure somebody can point you to the thread.
bagginsbill posted Sat, 04 July 2009 at 8:37 AM
ISF lighting will be ruined without gamma-correction. You need to do both for even a modest amount of realism.
Once you do those two things, you'll find that lighting your scene suddenly makes sense. You'll find that the Poser lights do things as you'd expect them to do based on your experience with being an actual human in the actual universe.
lakota posted Sat, 04 July 2009 at 9:10 AM
Well as a once and future Cartographer, I think I kind of understand simple math. As understanding "Poser's" simple math, that's something else.
I do know know that the suggestion by Miss Nancy to set the shadow setting on all the lights to 1.000 is in fact eliminating the "x-ray" ability of these lights to cast light through walls and tables and such, eliminating the odd lighting under the table. But the down side is it's creating a very harshly lite environment that doesn't seem natural at all. It looses all that subtle inter-play of the lights in the scene.
IsaoShi, if you could post bagginsbill's ISF widget and if he doesn't mind, I would like to try it.
IsaoShi posted Sat, 04 July 2009 at 9:15 AM
Here is the ISF shader. Save it somewhere in your Materials library folder and remove the .txt file extension.
The shader has four parameters. When you have positioned a light, its position must be copied into the XYZ parameters in the shader. This is so it can calculate the distance from the light source to the point on the surface currently being rendered, and hence the intensity at that point.
The other parameter specifies the distance from the light at which the actual light intensity will be equal to the light's dialled intensity. I usually leave the intensity dial at 100% and use this parameter to adjust intensity - I find this method more intuitive, but you can do it either way.
If you use Parmatic, it will create dials for these four parameters on the light's Parameters palette.
what I should be."
Murakami)
IsaoShi posted Sat, 04 July 2009 at 9:33 AM
By the way, the 'very harshly lit environment' you refer to is typical of images without gamma correction. Bad lighting is not the cause of this, it's simply because you are displaying a linear colour space render on a non-linear (sRGB) display.
I'll stick my neck out and say that with GC you will only need a single ISF point light at each source to achieve a realistically lit and nicely atmospheric scene. You could add a very low level IBL to simulate general ambient lighting, but my guess is you won't need to.
Unfortunately, applying GC to all those materials is going to be a fair amount of work!
what I should be."
Murakami)
lakota posted Sat, 04 July 2009 at 11:38 AM
In the second shot using ockham's suggestion to drop the lanterns main "Point" lights below the lanterns themselves and turning off the light in the lantern on the table, the softness and richness of the environment was still there and now adjustable. It gave some lift to V4's rump. However, it did eliminate the illusion of a bright flame in the lanterns, but thought I could add three more "point" lights within these lanterns with a shorter "End Dist" to restore that look. Granted it still had some floor shadow problems and under table lighting problems, but it seamed like progress.
Miss Nancy's suggestion to have all shadow setting set to 1.0 did eliminate that odd "x-ray" lighting below the table, but as seen in this latet test shot created what I think is very harsh lighting compared to the first two. V4's back is black, the face of the standing officer is flat and the seated officer's face is sliced down the middle, the lantern shadow pattern on the ceiling is very dark and the floor is just a maze of almost monotone bright shadows with very little definition under the table.
As to "Gamma Correction" I'm not sure exactly what that entails or where that is adjusted. I run a mac and back in os9, Adobe had a system extension to change the gamma setting of one's monitor for use with PhotoShop, but osx 10.4.9 doesn't seem to have that option in its system preferences anymore.
IsaoShi posted Sat, 04 July 2009 at 1:06 PM
There's a whole bunch of information on Gamma Correction here in the forums.
But put very simply, an unadjusted render coming out of Poser 5, 6, or 7 (Poser Pro has built-in gamma correction) does not have a correct Levels curve applied to it for display on any computer monitor -- because all computer monitors are calibrated to receive and display images with a specific Levels correction curve. This manifests itself in darker areas of the image being much too dark - exactly what we can see in your above image.
There really is sufficient light in those dark areas, but unless you gamma correct the image you won't be able to see it properly on your monitor. This is not to do with the gamma correction of your monitor, but of the image itself, so that it displays correctly on your monitor, and on everybody else's monitor.
(Having said that, I'm also on Mac, and I have adjusted my monitor gamma correction to 2.2 in the display calibration utility. With the release of Snow Leopard, Apple will set 2.2 as the default gamma correction in OS X. Up until now they have always used 1.8. This change will have the effect of making your images look even darker, but the point is that they will be closer to how most other people see them).
So what do you do? Well, the simplest thing is to apply a gamma-correction curve in Photoshop, using a Levels Adjustment layer. That will get closer to the correct lighting levels, but your material textures may begin to look a bit washed out. The reason for that is that the original colours of those textures were already gamma corrected in the image maps you are using, and now you are doing it again on the final render -- so they get too bright, and lose colour depth.
The correct way to apply gamma correction within the Poser material shaders is to remove gamma correction from the source image maps for the textures, and then re-apply gamma correction to the pixel colour values in the final render.
This is the method that is covered in depth by bagginsbill and others within the Poser forum threads on this subject. Most recently, bantha has posted a Python script which applies the required gamma correction nodes to a material shader.
what I should be."
Murakami)
Khai-J-Bach posted Sat, 04 July 2009 at 1:39 PM
now if we could get that shader to read IES Light files...
Miss Nancy posted Sat, 04 July 2009 at 2:11 PM
lakota, in tiger, use colorsync utility to see what yer image looks like on their PC monitors. it allows one to change the gamma from 1.8 to 2.2, which (in the simplest sense) will make yer image look darker. aside from bantha's gamma script, another way to spruce up the shadows and lighting is to enable the indirect diffuse calculations in poser's currently available FFRender, but in a 208 MB scene, such a render would take at least a week, hence the quicker way is to correct the textures as mentioned above.
bagginsbill posted Sat, 04 July 2009 at 5:00 PM
You should be using IBL as well. In this sort of environment, there would be a lot of secondary lighting bouncing off surfaces. Some IBL will decrease the harshness of the light/shadow comparison.
Personally, I would generate an IBL that matches the direct lighting you've produced, using my GenIBL tool. This would allow you to include some approximation to the indirect lighting of the scene that you would get if you had a render with global illumination.
lakota posted Sat, 04 July 2009 at 5:12 PM
Well, I do something with the gamma and setting it to 2.2. I don't think I used the colorsync utility, 'cause that is asking me to agree to its terms before it even opens, so I must not have evened it before. I opened "help" and typed in gamma, hit a link, then another link and walked through something. I did set that up before at some point when I installed a new monitor a few years back.
Fondly remember the "classic" old mac os when you knew where everything was and what everything did.
Now the images are a bit darker, but not by much. The scene is now 207 MB down from a high of 213.5 MB. It takes my old g4 Quicksilver ppc about 3 hours to render a 803 x 570 image of it set low in raytracing in firefly rendering. At finish rendering settings at 1170 x 708 with hair on the seated figure, that's a rendering best left to when you're sleeping and be surprised in the morning as to what it looks like over a good cup of coffee.
I need to experiment with bagginsbill's IFS shader. Maybe just rebuild the scene again, start afresh for the fouth time. Throw a lantern in an empty Blockhouse and see its effect then start adding the stuff again. It's all chunked together in my libraries, all parented together in some way or another, not hard to reload.
Excluding the figures and such, all the props and clothing are my stuff, so redoing the texture maps won't be that hard. Excluding the clothing, they are all in the same folder, well the textures for the Bockhouse are in one folder and the prop textures are in another. V4 Vickie's outfit is in another, the m4 officer's uniform is in another, and the m3 Soldier's textures in another. And all those folders are in one 1812 folder.
lakota posted Sat, 04 July 2009 at 10:58 PM
The point now is to get a handle on this effect, make adjustments to refine it, and then fill the room up with stuff again.
I should say, I tried lower settings of 100% Intensity, but that wasn't popping through the lantern's glass at all, unless something is dramatically wrong with the texture maps which have not been change or gamma altered in any way.
So here is the scene with only one lantern over the table in the room. The lighting is now an inter point light set at 200%Intensity, 1.000 Shadow, with a Dist End at 0.005.
And an outer Point light using the ISF shader set at 300% intensity, 1.000 Shadow, Dist Start at 0.500, Dist End at 0.000, and the Intensity Distance in the ISF shader at 500.000 for its value_1.
There is also a sky dome in the scene, but it's outside the room and shouldn't have that much effect.
I don't know if this is a correct setting with in a 20 x 20 x 10 foot room, but it's a starting point.
bagginsbill posted Sun, 05 July 2009 at 6:26 AM
You've missed the point completely. The Dist Start/End business is Poser's way of doing falloff and should be disabled. At Dist End, the intensity goes to 0. No light does that in real life - never goes to zero. That's why we can see stars from billions of light years away.
You must turn off all built-in falloff, then set up the ISF light. You will also need to use a gamma correcting shader to get these low levels if illumination to appear accurately on a computer monitor.
I know that doesn't seem to make sense - you've never need to before, right? But you've finally hit the wall where you can't ignore these things or hack around them with more light. Using more light spoils your scene.
Maybe others can chime in here to help with details. You've chosen to need help on 4th of July weekend - LOL. Those in the UK are around.
I"m about to head out for a day of sailing and drinking. They go together.
IsaoShi posted Sun, 05 July 2009 at 6:43 AM
The ISF shader I gave you, which was my own 'tidied up' version of bagginsbill's original shader, had some mistakes in it. The Ratio and PM:Intensity_Distance nodes were incorrectly set up. It does not give anything like the intensity of light that it should. I attach the corrected version.
Sorry, sorry, sorry a thousand times, to you and to bb, for distributing something of his with errors made by me. I think others have downloaded this incorrect version of the shader, and I'll raise another thread to try and put this right. I feel really bad about this... sorry.
I also forgot to mention to you that the ISF shader must have all its parameters entered in inches. I'll do another post in a minute showing what it should look like with the settings you are using.
(edit) "sailing and drinking go together...". As long as you are not at the helm, bb!
what I should be."
Murakami)
lakota posted Sun, 05 July 2009 at 7:00 AM
bagginsbill, respectfully, I don't think I'm missing the point completely.
I'm running tests on a shader node that I've never used and don't know anything about. I don't know much about Poser's material nodes to begin with. First tests created a more or less solid darken room with no illumination at all.
So I set up some parameters that lit the room and will work back from that.
Enjoy the day, lake is a bit calm here for sailing
IsaoShi posted Sun, 05 July 2009 at 7:05 AM
This setup would give an intensity of 4,800% at around 10.5 feet - far too much light for anything.
There's no point going into what's happening with the surfaces in my image, particularly the reflective tiles that are coming out black. The light is just so intense that my shaders are blowing fuses left right and centre. (In fact, this is a good demonstration of inherent inaccuracies in my shaders, that they should react to very intense light in this way).
what I should be."
Murakami)
lakota posted Sun, 05 July 2009 at 7:12 AM
Well, that might explain something.
But no need to fall on your sword over it. I often load my own wrong props from the wrong folder thinking that they are the right or newest version forgetting that I never throw the old one away.
I d/l this shader and will continue testing, but inches? I'm in feet or does just the node settings to be in inches
IsaoShi posted Sun, 05 July 2009 at 7:51 AM
If you want to enter these four parameters in feet instead of inches, you need to change the three values in the P node from 0.0969 to 1.1628. According to bagginsbill, the P node returns its position values in one-tenths of a Poser native unit, equal to 10.32 inches. This needs to be converted to whatever units you want to use in the parameter nodes.
Note to bagginsbill: while checking and double-checking the corrections to my version of the ISF shader, I have come across various versions (all posted by you) with different values in the distance Pow node and in the final Divide node. Can you confirm which values are correct, please? I don't want to post a thread with a corrected version if it's still wrong. Thanks.
(edit) the version I used for the above-posted correction is shown in the image above. The only difference is I did not round up the P-node conversion factors to 0.1
what I should be."
Murakami)
lakota posted Sun, 05 July 2009 at 8:56 AM
Here is a "test" shot of the interior of my Blockhouse again, now using the correct version or one of the corrected versions of bagginbill's ISF shader.
It has only one light source simply to test the effects of the shader and to just see what's what.
The setting for this ISF light are as follows:
Dist Start 0.000, Dist End 0.000, Shadow 1.000, Intensity 100%, Shadow Blur Radius 0.5, Shadow Min Bias 0.8, Atmosphere Strength 0.01, and in the ISF shader the Intensity_Distance Value_1 is set at 60 inches. I did not change any other settings.
For what it's worth, I think this test is doing what's suppose to do, figuring out things.
If I keep the Intensity_Distance Value_1 low enough, I eliminate the need for a second point of light within the lantern to emulate a bright flame. I did run a test with a Intensity_Distance Value_1 set at 120 inches, but the light seemed to bright within the lantern.
And that is where things are at the moment.
lakota posted Mon, 06 July 2009 at 7:07 AM
The center light is still centered and centered over the table set at 7.3 feet above the floor. The other two ceiling lights are at the same height 6.55 feet forward and 3.64 feet to the left and right of center. The light on the table is set at 3.6 feet above the floor, 2.5 feet to the left of center, and 1.1 feet back.
All the ceiling lights are set at 200% Intensity with the ISF's Intensity Distance set at 30 inches. The table light is set at 50% Intensity with the ISF's Intensity Distance set at 30 inches as well.
The scene's lighting is improving, but still needs work.
It has lost the illusion of a bright flame in the lanterns which was there when the two outer lanterns were set back from their present location 3 feet with all lights were set at 100% Intensity with the ISF's Intensity Distance set at 60 inches. However, this setting burned to white the top of the table, but lit the walls and ceiling nicely, casting real sweet shadows although the room in general was a bit bright for the desired mood.
At the moment, I can best describe the lighting as something you might see on a stage in a theater in some scene from a play. It is dramatic, which is the wanted effect, but here, I don't know why the light would be so white under the table.
I would guess some of the problems are caused by the panes of glass in the lanterns themselves. They are not one sided, they have depth.
In addition, I have yet to change any of the texture maps to "correct" the Gamma point as has been suggested to improve the realism of the scene.
lakota posted Tue, 07 July 2009 at 4:44 PM
The lighting isn't right yet, but the unexplainable bright shot on the floor is almost gone. I thought I had that solved, but Poser crashed and I hadn't saved any of the numerous experimental changes to the ISF Intensity Distances settings made to try to eliminate it.
Yet, I still have no clue as to why Vickie's foot under the table is lit so strongly. To me it makes no sense, if one of the spot lights was the cause, one would think that the forward legs of the table would be effected as well.
bagginsbill posted Tue, 07 July 2009 at 4:58 PM
Did you read off the coordinates of your lights in inches, and type those into the ISF shader as inches? What are your Poser display units set to? What values did you put into ISF for the light coordinates?
Suppose your light is 6 feet off the ground, and you used feet as units, and typed in 6 for the ISF Y position. That would be 6 INCHES, and so you'd get maximum light under the table instead of above it.
lakota posted Tue, 07 July 2009 at 5:24 PM
My units in Poser's preferences are set to FEET.
With in your shader they are set to INCHES (I believe).
The main center point light as well as the two spots are set at 7.326 above ground, the floor is 0.02 above ground. It is set at 70 inches (5.83 ft) for Intensity Distance.
The spot lights are both 3.64 feet left and right of center, 10 feet forward and angled down 12 degrees.
bagginsbill posted Tue, 07 July 2009 at 5:38 PM
But the shader is set up for inches. That is what I was talking about.
You entered your light position into the shader using units of feet. You typed 7.326. That is in feet. But the shader uses inches. That's why you're getting the brightest light 7 inches from the floor. You told the shader the light is 7 inches from the floor.
You need to do the conversion to inches, i.e. 7.326 feet * 12 inches/foot = 87.91 inches. Or, as I always suggest, set your Poser display units to inches and then just read the posiiton off the dials.
lakota posted Tue, 07 July 2009 at 5:45 PM
Thanks bagginsbill,
I was just looking at that screen shot and pondering that possibility.
bagginsbill posted Tue, 07 July 2009 at 5:49 PM
I wonder if there is some misunderstanding about the units.
Poser display units only change the meaning of numbers that are in Poser parameters that are used exclusively for dimensions or distances.
The math nodes in a shader are unitless - they do not change they're units just because you're using them to represent a distance. Poser has no way of knowing these things.
So regardless of what you've chosen for Poser display unit, the numbers you enter in the shader position nodes MUST be in inches.
Oh, and Izi, you said to support the shader in feet, change the .0969 values in the P node to 1.1628 (.0969 * 12). You got it backwards. That would make it give data in units that are 1/12 of the inch. You need to DIVIDE by 12, not multply by twelve. If you're starting with a measurement in inches, you DIVIDE by 12 to get the same measurement in feet.
The correct multiplier for the P node in feet is .0969 / 12 = .008075.
But then we'd have to express the reference distance in feet as well, which would require more changes. This is confusing enough as it is. Just everybody use inches for everything and the shader will work right.
bagginsbill posted Tue, 07 July 2009 at 5:54 PM
Quote - Note to bagginsbill: while checking and double-checking the corrections to my version of the ISF shader, I have come across various versions (all posted by you) with different values in the distance Pow node and in the final Divide node. Can you confirm which values are correct, please? I don't want to post a thread with a corrected version if it's still wrong. Thanks.
The value in the reference distance pow node is different because it's whatever I want it to be. For example, if I know that I have an object that is 42 inches away, and I want the luminance to be 80% at that distance, then I put 42 in there and 80% intensity. If I want 60% intensity at 90 inches, then I put 90 in there and 60% intensity.
I'm not aware of differences in the final Divide node, unless those were cases where I was not using a Pow node for the distance. Sometimes I used to just put the square of the reference distance in the divide, but that was harder to understand. So the divide is always 1/3 and the 1 is connected to the reference distance node which squares it. [ Pow(d, 2) ]
IsaoShi posted Wed, 08 July 2009 at 11:50 AM
Sorry, bb, I wasn't clear. I was referring to the Value_2 dials in both the distance pow node and the final divide node, not the Value_1 dials.
Your second paragraph explains some of this. But I also saw a version with (I think) 1.3 in Value_2 of the final Divide node. I vaguely remember something to do with simulating light coming in through a large window... the Pad, maybe. Don't worry about it, if I ever find it again there will probably be an explanation to go with it.
what I should be."
Murakami)
IsaoShi posted Wed, 08 July 2009 at 12:13 PM
Quote - The correct multiplier for the P node in feet is .0969 / 12 = .008075.
Oops.. I struggled with that conversion, first one way then the other, and eventually came down on the wrong side. A blind spot!
I think you only need to change the three P node multipliers, and then enter all four parameters in feet.
But I agree.. we should all use inches and be done with these conversion issues.
what I should be."
Murakami)
bagginsbill posted Wed, 08 July 2009 at 12:47 PM
Quote - Sorry, bb, I wasn't clear. I was referring to the Value_2 dials in both the distance pow node and the final divide node, not the Value_1 dials.
Oh, I remember that. Yes you may want to change that.
From my physics classes, I recall that the inverse square [ pow(distance, 2) ] relationship is only for an idealized point source. For an infinite plane, the relationship is inverse linear [ pow(distance, 1) ]. For any real light source that is neither an infinite plane, nor an infinitesimal point, the best approximation is a power law somewhere between 1 and 2. That's why I wrote a 1.3 in some cases.
IsaoShi posted Wed, 08 July 2009 at 1:42 PM
aha, that explains it - thanks!
bb, I spent the whole journey home this evening puzzling over what we are doing with that P node in the ISF shader.
I can't believe you got it wrong, but neither do I understand why it is right. Another blind spot, perhaps. Can I break down my thinking, so you can put me right.... (sorry to ask, I know how little time you have, but it should be quick).
Thought 1: The P node, I believe you said, returns its values in strange units equal to one-tenth of a Poser unit... or 10.32 inches. So if our scene has a point on a surface which happens to be positioned at XYZ = (10.32, 10.32, 10.32) inches, the P node when rendering this point would return a value of (1.0, 1.0, 1.0).
Thought 2: In order to compare the above P-node position with the point light position that we enter in inches, we would have to multiply the P node values by 10.32. So, for example, if our ISF light position was also at (10.32, 10.32, 10.32) inches, the difference would come out at zero, and our calculated intensity would theoretically be infinite.
Thought 3: Instead of which, the ISF shader divides the P node values by 10.32 (multiplies by 0.0969) before comparing with the inch values.
One of these thoughts must be wrong, but I can't see it. Is it simply that the P node returns its values in 1 / 1000th of a Poser Unit, not 1 / 10th? Please help me sleep tonight!
what I should be."
Murakami)
bagginsbill posted Wed, 08 July 2009 at 2:03 PM
Approximately tenth of an inch, not a tenth of a PNU. Or, more accurately, 1/1000 PNU.
Miss Nancy posted Wed, 08 July 2009 at 5:04 PM
if lakota is still reading this thread, should be apprised that they augmented the indirect diffuse algorithms in poser 8 to the point where it'll now be practical to render OP's scene with much more pleasing results in re: lighting.
lakota posted Wed, 08 July 2009 at 6:30 PM
Thank you for the information, Nancy
I'm still trying to get the scene lit. Now I'm having the problem of the over all scene lit well, but now the lantern's pure white. It I get the lantern looking good, the rest of the scene is dark and unaffected by the enclosed light. I can't get the light to pop out from behind the glass unless it explodes the lantern glass and top to bright white
I still think it is easier to just export the geometry of a scene to a better renderer, 'cause I've been working on lighting this scene in Poser for three weeks now. I don't recall it being this difficult in other programs.
However, I'm still chugging along
lakota posted Thu, 09 July 2009 at 11:13 AM
In review:
Using standard point lighting with no nodes and using the intensity and shadow dials to control the lighting, I was able to achieve a somewhat realistic look to the scene until the light reached a point below the table and then it just didn't work. The shadow dial settings allowed Poser's odd "x-ray" lighting to light areas that should not be lit and the low shadows setting were ghosting the shadows on the floor to almost nothing.
After being informed of the true effects of Poser's shadow dial, numerous attempts were made to correct this by keeping all shadow setting to 100%, but this created a very harsh environment with no subtleties to the shadows on the floor.
After this, bagginsbill's ISF shader was used. Although by mistake I was inputting the wrong location of the lights in his shader node, after numerous trail and error tests I was able to achieve most of the desired effects until the light hit the floor with bright spots of light and the shadows were off due to the wrong information as to the lights locations.
After this, a forth series of trials were started using the correct location information entered into the ISF shader (I was entering the info in feet when it should be in inches). In these tests, I was able to get the room lit within an acceptable margin to just be able now to tweak the lighting settings with all shadows behaving as they should, except now I have the problem of the lantern washing out to bright white.
In this example the point light in the lantern is set to 50% intensity with an ISF intensity distance set to 60 inches. It illuminates the figures and table well and creates a nice lighting effect on the ceiling. The only problem is that the lantern is bright white. A test was made with the lantern not visible and the lighting was still good.
lakota posted Thu, 09 July 2009 at 11:14 AM
My best guess now is to add a shot light pointing up within the lantern to create the ceiling lighting effect and another spot light pointing down just under the lantern to light the figures and table.
Obtaining this flame glow in some form or another within the lantern's glass structure and lighting the room is the goal without doing any post rendering in PhotoShop. I know cutting a lantern out of one pic and adding it over another is not difficult, but that is not the point.
bagginsbill posted Thu, 09 July 2009 at 12:21 PM
Did you ever start using gamma-corrected materials? If not, you're just spinning your wheels. As we said on page 1, this sort of subtle lighting is impossible to get right without gamma correction. Bantha posted a python script that will assist with converting each material to a gamma-corrected material.
Without gamma correction, you are choosing to increase the light intensity in order to compensate for how dark other things are appearing at a distance. This forces the local luminance inside the lamp to very high levels. As a consequence, the lamp is becoming over lit. Once your materials in general are responding to lighting correctly, then you will be able to light the room quite easily with a much lower intensity.
As for the ISF falloff, you mentioned trying to set the intensity very high at 2 inches. This is just forcing you to guess what setting to use to accomplish what luminance you want at other distances. But various combinations of distance and luminance produce equivalent values that you'd get the same results with at other distance and luminance settings.
For example, the following are identical:
2 Inches 1000%
60 inches 1.1111 %
See what I mean? Whatever you choose for 2 inch luminance will result in 900 times less than that at 5 feet. Similarly, whatever you choose at 5 feet will result in 900 times more luminance at 2 inches. ISF is an approximation that is only accurate at close distances if the light source is an infinitesimal point.
In real life, a flame is not a tiny dimensionless point. It has a definite non-zero volume. In other words, the total energy from the flame is not concentrated in a single point. If the tip of the flame is two inches from the top of the lamp, then all the other parts are more than that. The real-life result is that the local luminance inside the lamp is never 900 times the luminance at 5 feet. But that's what the math here produces.
As a workaround, I suggest that the shader on the lamp be adjusted to produce less diffuse reflection. Instead of a Diffuse_Value at or close to 1, I'd suggest a much smaller fraction. What I'm saying is, get your gamma correction going, get the luminance at 3 feet or greater looking right. Then, decrease the reflectivity of the lamp until you've compensated it enough to look like it is lit by a local 3 dimensional flame, instead of a dimensionless point with infinite light density at the origin.
You will also want to employ some IBL because in a closed environment, the primary light source gets bounced around so that all the objects in the room become secondary light sources for all the other objects in the room. With Poser 8, this is automatic, but you don't have that, so you need to use a very low level IBL to approximate the overall secondary lighting.
bagginsbill posted Thu, 09 July 2009 at 12:26 PM
Note: Don't even waste your time incorporating IBl until you get the GC set up. Low levels of lighting are off by a factor of 10x without GC. Without GC, you'll try using an IBL that is much too bright, and the whole thing will fall apart again.
lakota posted Thu, 09 July 2009 at 1:52 PM
Thanks, bagginsbill, and thank you for your patience.
I did kind of figured your system was akin to a camera's f-stop and shutter speed relationship. Or water pressure and pipe diameter, not scientifically maybe, but a good visual reference.
I am still toying with it.
The extreme test settings were just that, tests, tests of one variable while keeping the other constant. I get something working in one method that doesn't apply to the next method used.
Basically in all these tests I'm been just moving problems from one corner of the room to another. Each test rendering takes about three hours to render on my Mac, so progress is slow. It is all been kind of like sweeping the floor but never using a dust pan to pick anything up. The best hope has been to make the pile as small as possible and then sweep it under the rug somewhere.
As to materials on the lantern, there are no texture maps. There is a transparency map to create the holes in the top to produce the effects on the ceiling. I think the lantern frame is black, highlight gray, ambient black, reflection white. In my book, given that the scene renders relatively well without the lantern there, it must be in its material settings or its construction. Or I am trying to accomplish two distinct effects not necessarily related to each other a node setting.
I don't know, as I wrote, generally I just move a scene out of Poser and work on the environmentals and lighting in another program. I'm an old school illustrator, I'm visual.
This is all reverse from my thinking on the functions of math. Given an aerial of tire tracks in the sand, I was taught to figure out the probability of what type of vehicle produced them, how much cargo their might be carrying, and what that cargo might be. I was not given a set of numbers, equations and variables and asked what the image in the sand would look like if it were a specific vehicle with a know cargo.
As to a glow, it is the reflective glow or halo of a light bouncing off the glass that I was referring to. That is all based on the reflective qualities of the object behind it, that object's angle to the light in relationship to the camera angle.
If it were a painting, I would get out an airbrush and do it. Throw in the artistic concept of studying the physical work, the paint on canvas and winging it with soul.
bagginsbill posted Thu, 09 July 2009 at 2:24 PM
For example, it's quite "illuminating" (forgive the pun) to visualize the curve of the inverse square luminance as a function of distance, as pictured above. I have this image in my head when I think about lighting.
The X axis is distance in inches. The Y axis is Poser light intensity. I chose to graph a light that is 50% intensity at 5 feet (60 inches).
Have a look at 10 feet (120 inches). The intensity drops to 12.5% - still a respectable amount of light.
But the surprising thing is the extreme slope at the low intensities. At 30 inches, we're twice as close, therefore four times brighter at 200%.
At 10 inches, this same lamp is producing energy at 1800% intensity!!!! Imagine what the value is at 2 inches.
So why does lantern glass look relatively dim? Because it only catches a tiny amount of the light passing through it. The "glass" needs to be not 98% transparent, but something like 99.99% transparent, otherwise it's going to look hot as hell.
lakota posted Thu, 09 July 2009 at 9:11 PM
I downloaded Bantha's Gamma assistant as suggested and used it to convert most of the major components in the scene. I didn't do all of them, 'cause these are tests, but I did correct the officer's uniforms, the majority of the m4 textures, floor and walls, flags and picture. I did correct the table, but not what is on it. I used the GC button.
I then deleted all lights except the main center light. I deleted the lantern as not to interfere with the test rendering. I did try setting the transparany of the glass to 99.98%, but it was still burning to white.
I set the intensity to 100% and the ISF intensity distance to 30 inches.
However, something is again is creating light under the table and not producing floor shadows. Now my ISF intensity distance might be off to produce shadows now that the scene is brighter, but prior to using the Bantha's python script and changing the gamma setting on most items, that issue was fixed and although a dark scene without this correction at least it was functioning as I thought it should.
bagginsbill posted Thu, 09 July 2009 at 9:46 PM
I have to think you've got the coordinates wrong. Try disconnecting the node from the point light intensity and just render with it normal, no falloff. Do you get shadow under the table?
For speed testing purposes, I'd hide the figures and just deal with the walls, floor, ceiling, and table.
I'd also change Pixel Samples=1, Min Shading Rate = 3, and render only about 200 pixels wide. That's all good enough to see how much light falls everywhere. Should be 50 times faster.
bagginsbill posted Thu, 09 July 2009 at 9:48 PM
Looking closely, I don't see shadows ANYWHERE. Are you sure you have shadows enabled and raytracing enabled? Point light shadows only work with raytracing.
lakota posted Thu, 09 July 2009 at 10:10 PM
Bagginsbill, That's it shadows were off. Poser is running so slow, it doesn't click on very well and may click off by clicking on twice and not knowing it. While writing this, its clicked off three times which might be from clicks I made minutes ago.
Never mind
I'm going to start from scratch and just reload the scene again.
maybe have a good stiff drink first
lakota posted Fri, 10 July 2009 at 11:52 AM
Turns out I had a problem of a cross circuit male plug plugged into the USB hub that was causing erratic click commands from my mouse in an already slow responding Application. It would repeat clicks, skip clicks, and so on. So clicking on the raytracer shadows and then clicking out to another window was causing it to turn on then off and then opening another window. I did not notice at first because poser is always slow on the draw and thought it was bogging down from the file size and changes being made.
Right now I'm spending the day using the gamma correction Wacros to modify all the material setting in the scene. There are a lot of them, lot of props and parts of props to do. I do wish this was a batch process and not an individual thing. This is a very lengthy process.
bagginsbill posted Fri, 10 July 2009 at 1:26 PM
I believe that if you load the script into a Wacro button and do a Ctrl-Click (or Shift-Click) or something like that, it will run the script on all the materials of the currently selected figure or prop. That might speed things up.
lakota posted Fri, 10 July 2009 at 2:49 PM
I hear that is true, it states that. However, running a mac, that feature doesn't work or never has with my experience. That might be a feature that works in Windows, but never checked after porting it to Mac.
So for me without that feature its about 25 figures plus 30 props times an average of 6 materials per item times 4 clicks per material. Started at 8 am and I'm a little over half way. Just two figures and their props away from being finished with this simple step.
lakota posted Sat, 11 July 2009 at 12:55 AM
I have made all the gamma corrections suggested using Bantha's wacros using the simple "GC" button in a process that took more then 8 hours. The time is a mac thing I guess.
I am still working on getting the lantern not to burn out and still light the area of the officers and table top. The candle on the mantel needs the ambient color darkened and the light place more in front of the flame in line with the camera to help in the illusion of a halo. The light in the embers in the fireplace needs to be nestled more between the log and the embers themselves to cast light a bit more forward. And the indirect lighting of the two spot lights need a bit more work.
In addition the background lighting emphasizes should be more on the left and fade to dark near the soldier on the right side of the frame. The standing officer's shadow from the lantern not clearly seen between V4's arm and waste in the cause of that.
However, besides the main lantern lighting problem, I am thinking that the gamma corrections have produced a white light or cool lighting environment, (modern florescent lighting comes to mind) as a pose to a warm light generated by dingy old candle light.
In any event, the main center light is set at 25% intensity with a 48 inch intensity distance setting. The glass is set at 99.999% transparency.
The light in the lantern on the table is set at 30% intensity with a 48 inch intensity distance setting. The glass is set at 98% transparency. I don't know what the top of the lantern is doing.
The candle light over the mantel is set at 100% intensity with a 2 inch intensity distance setting.
The fireplace light is set at 10% intensity with a 36 inch intensity distance setting.
Both right and left frame side spot light are still 10 feet out, 3 feet over and 7 feet up off center and set at 20% intensity with a 100 inch intensity distance setting.
IsaoShi posted Sat, 11 July 2009 at 5:27 AM
Remember to increase shadow blur for the lantern lights. A lot of light would be reflected off the insides of the lanterns, so you need softer shadows from these than from a naked flame.
It looks like you are using pure white for the candle lights, which would be quite yellowish.
Without looking back in the thread, I think bb suggested that once you have adjusted your ISF point lights to the way you want them, you can try reducing the diffuse value of the lantern materials so they don't look too 'hot'.
The candle on the mantlepiece would illuminate the left part of the picture, particularly to lighten the standing officer's shadow that you mention. It does not seem to be giving out much light at the moment. Also, its position is such that it is lighting the candle itself, which looks too bright.
Final touches could include using a 'glow sphere' around each candle flame, and perhaps using a touch of depth cue to simulate some smoke in the atmosphere. I would even be tempted to try volume when everything else is done; but if you do, be prepared for some very long render times!
(edit) by the way, I'm on Mac and Shift-Wacro works fine for me. It does not appear to depress the button at all, but it does perform the requested action.
what I should be."
Murakami)
ice-boy posted Sat, 11 July 2009 at 5:45 AM
the light is above the table yet it looks to me like its infront of the table.
it took 8 hours to replace the materials? hmmmm something is wrong here.
lakota posted Sat, 11 July 2009 at 10:02 AM
As to the "Shift-click" textures to all, this feature has never worked for me. I've tried it when loading image maps as well and it that case the "Browser" button goes Blank looses the word "Browser", but only loads the texture on one part. Maybe that's a Mac PPC thing and not an INTEL glitch. I don't know, somethings I give up trying to understand in Poser.
If this feature had worked for me, the time it took to modify the setting would have been greatly reduced. Think of how many texture parts V4, M4, and M3 are divided into, 15 or so? For me to chance one was 60 clicks of the mouse and if it had worked it would have been 4. That is the reason it took so long.
lakota posted Sat, 11 July 2009 at 11:00 AM
There is also the strange thing that when I reopen the scene in Poser the main center light is now set at 100% intensity using a 75% blackened light as a pose to the setting of 25% intensity. This might be of no real difference, but the other lights are still set as before with no changes.
But such things are common in my experience. Another example would be that I delete a red British coatee on the m3 figure and add a blue US coatee, Poser does this, but changes all the material setting on his cross belts to a brass tone equal to one of the many material settings on that conforming figure.
It's glitchy, always has been
bagginsbill posted Sat, 11 July 2009 at 1:01 PM
Quote - As to the "Shift-click" textures to all, this feature has never worked for me. I've tried it when loading image maps as well and it that case the "Browser" button goes Blank looses the word "Browser", but only loads the texture on one part. Maybe that's a Mac PPC thing and not an INTEL glitch. I don't know, somethings I give up trying to understand in Poser.
I'm sorry to be abrupt but you're using different words, which leads me to believe you may not be paying attention.
We're not talking about shift-clicking materials or textures or images. We're talking about shift-clicking a WACRO button. I mentioned that you should connect the script to a wacro button. You never once used the word WACRO so I'm assuming you simply paid no attention. Sorry if that's not the case, but it's very time consuming to explain these things repeatedly and hear that it only doesn't work for you, not the rest of the universe.
Perhaps your response should have been "I don't know what a wacro button is"
lakota posted Sat, 11 July 2009 at 2:03 PM
Well, bagginsbill,
sorry that I don't use the word "WACROS" as often as I should. I forget how to spell it at times.
In Poser / material / advance there is a Wacros: menu on the right side of the window, close to the bottom there is a button that reads "User Defined" in that sub menu there is Bantha's "CG." Below the User Defined button and seperated by a line it reads: "Click button to apply action to current material" and right below that statement it reads: "Shift-click button to apply action to all materials of current object"
I am saying, I have never been able to get that shift-click feature to work. The click feature works and so I use that. I don't think this is a reflection on my abilities to operate Poser in some respectable fashion one way or another. I also don't think it is a reflection on the ease of use of Bantha's widget or your lighting system. Both of those seem to function very nicely, I discovered that I need to bump up the yellow in the lights to compensate for the gamma correction. These are things you learn as you adjust the setting from one lighting method to another.
It is not a big deal and if this "Shift-click" option failure is limited to my experience only, so be it. I have grown out of reinstalling the system and software every time I find a small problem. There might be a conflict somewhere, but that is not an issue.
I was trying to point out the fact that if it had worked, the time it took to adjusts these setting would have been greatly reduced.
The important point is that they have now all been corrected as you stressed should be and now the information and other recomindations to the scene you have suggested can be seen in the light of day, and more importantly understood better.
Common ground
Miss Nancy posted Sat, 11 July 2009 at 2:32 PM
lakota, i didn't read all the above msgs but are ya using poser 5?
just asking because poser 5 X was no good. poser 6 was also inadequate IMVHO.
shift-click and python scripts work o.k. in P7X for me, at least. I dunno about the others.
in re; trying to do system maintenance so that poser and other apps work as desired,
ask in mac forum. the deal about uninstalling and re-installing apps is a windows
technique, usually unneeded in OS X. meaning uninstall/reinstall may make no difference
in OS X.
lakota posted Sat, 11 July 2009 at 3:12 PM
Miss Nancy, it's 7 with sr3 with OSX 10.4.11 on an old PPC Quicksiver 933 with 1.25 gigs of RAM. I've been running poser since version 1 on a performa running os 7.5 or 8 or something. Ran through version 1, 2, 3, 4, poserpro, 5, and missed 6. I'm on my 6th computer if you don't count laptops. My knowlege of mac systems goes back to OS 6.8 and using Swivel3d, and PhotoShop 1.
Back in OS 9 and below, I knew the system a lot better. I don't do much to it anymore, too many folders and hidden files to be playing around with. OSX works and doesn't crash, that is all I expect out of it.
Things in poser are sometimes glitchy and you work around them. Some glitches found in version 3 were made into features in version 4. Some glitches just stay around. I am not an expert in this, if it functions fine, if not find a work around. Spending 8 hours as a pose to 2 hours to make these corrections was a very simple work around, I thought. It's my time, not company time.
The "shift-click" issue is an odd off target tangent subject to this project. Perhaps I should not have mentioned the time it took to load the gamma corrections and the reason it took so long.
lakota posted Sun, 12 July 2009 at 7:02 PM
Initially the problem with lighting this scene was by using Poser's standard point lights and adjusting their Shadow and Intensity settings, I was able to basically light the room, but it was causing unnatural light to appear under the table and washing out the Floor shadows.
It then was explained that the Shadow dial settings used allowed the light to pass through solid objects and that this was the cause of the problem. However, keeping all Shadow setting at 100% were producing a very harsh lighting environment with little to no inter-play in the shadows.
It then was recommended to try bagginsbill's ISF Shader on the lights, which is designed to be used for interior. Basically, to my understanding, a work-around to Poser's interior lighting problems corrected in PoserPro.
After a short but relatively bumpy trail and error period, I was able to re-light the scene using this system, but was having a problem with the lantern light effect. Basically, using one point of light I was able to get the lantern looking right, but then it wasn't lighting the table area below, or I could get that area lit, but the light would burn out the lantern.
After numerous test adjusting the intensity and the intensity distance settings, I speculated that there was a flaw in the design of the lantern itself. However, it was stressed that no true solution of the problem could be address until the gamma corrections were made to all the materials in the scene. I did this using Bantha's GC "Wacro." This improved the lighting and visual effects of the shadows , but had little effect on the problem I was attempting to resolve.
I then opened up the object file of the Lantern and made some corrections. The original lantern was dependent on a transparency map to create the illusion of small holes or heat vents in the top. This map also created the light patterns on the ceiling. In Carrara, I just cut square openings in the top to make this object less transparency map dependent.
Basically, in poser's standard lighting system this was creating an effect that was not effected by intensity or Shadow settings. Using the ISF shader it was burning this map out at higher light settings.
That reworked lantern resolves this problem and thus resolves the series of problems this thread has addressed.
FYI: The above pic has only the one point light in in the scene and that is in the lantern. It is set at 100% intensity and 36 inches for Intensity distance with the glass in the lantern set at 98% transparency. It is only a test.
Thank you all for your input and assistance.
bagginsbill posted Sun, 12 July 2009 at 8:13 PM
Oh ho! That looks right. Still need a little IBL but you're very close.
IsaoShi posted Mon, 13 July 2009 at 6:34 AM
And a useful summary of the whole process!
One small point of clarification: Poser Pro does not correct the light falloff issue. In this respect it's the same as Poser 7 / 6, and it is still necessary to use the ISF shader for correct falloff.
The essential ingredient that Poser Pro would have provided is gamma correction, both 'reverse' GC on source image maps and colours, and GC on the rendered image. So it would not have been necessary to put GC nodes into all the material shaders.
what I should be."
Murakami)
