Subject: Computer Sluggishness Could it be affecting WardrobeWizard 1 clothes????
tebop opened this issue on Jul 04, 2009 · 5 posts
tebop posted Sat, 04 July 2009 at 3:48 PM
Hey guys i converted some clothes long time ago using WW1.  I used them for a long time. Worked perfectly.
Then i started using them today an d suddenly, the clothes are shaped as if they were meant for the V3 default figure, which is not what is supposed to happen.
And when i conform them they dont fit.
THE THING IS.....i load the clothes a couple of times, and then on one of those times, the skirt was shaped like my figure's shape.. and when i conformed it , it fit perfectly...
So, you see? Sometimes its working and sometimess it's not.
This is odd.... but since 2 days ago my computer has been kind of sluggish i wonder if that's what making the WW1 converted clothes not work.
Khai-J-Bach posted Sat, 04 July 2009 at 3:50 PM
I'm beginning to think you need to take a good look at your computer and poser setups.
it's sounding more and more like you've got problems which are more than poser there. you may need to clean up your OS or reinstall Poser.
seriously.
tebop posted Sat, 04 July 2009 at 4:06 PM
 ohhh ok. yes, i haven't cleaned my system in a while. I will do that, thanks alot.
By  the way, here's an example. I was loading the dress , loaded it a couple of times and look , it was as if it were for V3 default figure, it doesn't fit my v3 morph character.
tebop posted Sat, 04 July 2009 at 4:07 PM
 Then i kept deleting and putting back on.. and finally it worked. I also kind of click on the background area of the screen and then the dress reshaped.
Here it's perfect. And it's the same dress
tebop posted Sat, 04 July 2009 at 8:06 PM
 Ok i'm back guys. I Repaired my computer and now everything is working!! plus my computer is not sluggish anymore.
Remember i told you how everytime i loaded WW1 converted clothing, it would take the shape of v3 default? well , no more. Now i load it and it works. It conforms and everything.
Greaaaat!!! I'll go back to my project
