Subject: Can the eyelid cast a shadow on the Iris?
hemi4261 opened this issue on Jul 08, 2009 · 9 posts
hemi4261 posted Wed, 08 July 2009 at 10:35 AM
Hi, I have a question regarding V4 eyes and shadows. When I have an infinite light with raytraced shadows in the correct angle (say, x-rotate -30 degrees), shouldn't the eyelid cast a shadow on the Iris map? I have tried adjusting the Min shading rate and cast shadows is of course enabled, but I don't get this to work. Any idea?
Free Centaur morphs for V4,M4,M3,AM,A3 and the Daz Millennium Horse
pjz99 posted Wed, 08 July 2009 at 10:43 AM
What is Shadow Min Bias set to?  Also when lighting for indoors, you probably shouldn't use Infinite type lights, they're really just for simulating "coherent" light sources like the Sun.  Spotlights are more appropriate.
My Freebies
hemi4261 posted Wed, 08 July 2009 at 10:49 AM
Thank you for the fast reply, shadow min bias was set to 0.8
About the infinite light: I assumend this would simulate something like "parallel" light rays from a very distant source, so this would give nice shadows...
pjz99 posted Wed, 08 July 2009 at 10:56 AM
As long as you're trying to simulate sunlight that's well and good :)
Set Shadow Min Bias to .1 or a bit smaller and see if you get your eyelid shadows.  Be aware this makes render time go up.
My Freebies
hemi4261 posted Wed, 08 July 2009 at 1:09 PM
Thank you pjz, that did the job. In case somebody else is interested,here's a comparison. In my opinion the right looks a lot more realistic.
pjz99 posted Wed, 08 July 2009 at 1:47 PM
Yep that's a big improvement.
My Freebies
lesbentley posted Wed, 08 July 2009 at 8:16 PM
IMHO, in the right side image the eyes look better, but the shadows on the lower eyelids are way too strong, and way too sharp.
hemi426 posted Thu, 09 July 2009 at 11:14 AM
Is there a way just to reduce the shadows of the eyelashes?
It's a very dense transmap, though.
pjz99 posted Thu, 09 July 2009 at 11:22 AM
The best ways would be to render with area shadows and global illumination, but a more reasonable alternative (for now) is to get some blur into the shadows and use fill light(s).
My Freebies
