moushie opened this issue on Apr 21, 2001 ยท 4 posts
moushie posted Sat, 21 April 2001 at 2:22 PM
I just can't make the character's eyes point at the Main Camera, which is animated, while I have Main Camera selected; they turn down instead. And it's the same if I select and "point to" the Posing Camera. Moreover, some of the time Posing Camera isn't even shown in the panel as a Point To choice. I have succeeded in the past, but it isn't working now. Any idea what's wrong?
ScottA posted Sat, 21 April 2001 at 3:08 PM
I think someone once said that pointing the eyes at cameras was buggy. And tempermental. Try loading the ball prop. Put it right behind the camera. Parent it to the camera. Then point the eyes at the ball instead. ScottA
bushi posted Sun, 22 April 2001 at 2:10 AM
Along with Scott's advice, I'd also suggest that you try setting the scale on the camera to %100. For whatever reason, sometimes the scaling on the camera will effect where the eyes point in a situation like this one. This doesn't always work but in many instances it corrects the problem. BTW when you set the scale to %100, you'll have to reposition the camera for the working view.
moushie posted Sun, 22 April 2001 at 10:15 AM
Thanks; buggy indeed. Scaling the camera to 100% almost does it in this case. Eyes are just a few degrees off laterally. The ball puts them farther out. Much appreciated.
