Subject: Can I ask about "Conform To"
smalll opened this issue on Jul 09, 2009 · 7 posts
smalll posted Thu, 09 July 2009 at 1:17 AM
Hi.
I need your help again.
I'm sorry.
I made a figure.
It is very simple.
And I conformed to man.
But result is terrible.
You can download it.
http://www.bokgi.net/test/accessaries-1.zip
Can you tell me how can I fix it?
What is the problem to me?
Help me please.
geep posted Thu, 09 July 2009 at 4:08 AM
Hi xmalll.
You might try this ...
  1. Select the "chest"
  2. Open the Joint Editor
    [menu] "Window" >>> "Joint Editor"
  3. Change the "Joint Order" (at the bottom of the Joint Editor" window) to "YZX"
    (click on the small down arrow and select "YZX")
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
pjz99 posted Thu, 09 July 2009 at 5:29 AM
For Conform to work, the way your clothing figure is rigged must be pretty much the same as the figure that will wear it.  Do not create these bones by hand in the Setup room (unlike your sword project);  you need to load the bones from the library in the Setup room.  Is this the "P4 Nude Man"?  If so, then you should try these steps:
This is the minimum number of steps that will get you a working, conforming figure.  There is some clean-up work to do with your new figure, in that it has a lot of joints and morph information that is not useful, and should be removed.  Some of this can be done in Poser:
with your new figure loaded...
You should leave the bones at the "root" of the tree (Body, Hip, Abdomen in your case).  Your conformer may work without them, but most people leave those root bones in.
Removing extra morph information is more complicated, you should probably look into a CR2 editing program.
My Freebies
pjz99 posted Thu, 09 July 2009 at 5:31 AM
Also note that "Auto Group" is only good for very simple models; if you have a very complex model, Auto Group will make a big mess.  As you keep learning, you will probably want to learn to make polygon group selections by hand in your modeler (unless you already know this).
My Freebies
geep posted Thu, 09 July 2009 at 1:50 PM
*(click the image to view it full size)*
Hi smalll,
I hope this helps you to fix your problem.  😄
cheers,
dr geep
P.S. BOTH NAMES can be edited in the Setup Room as shown in the image above.
cheers,
dr geep ... :o]
edited 10/5/2019
smalll posted Thu, 09 July 2009 at 8:01 PM
I'm very excited about you.
I'm deeply moved by your kindness
 I can´t find the words to thank you.
 Thanks to Mr. geep and Mr. pjz99
geep posted Thu, 09 July 2009 at 8:04 PM
cheers,
dr geep ... :o]
edited 10/5/2019
