AnyMatter opened this issue on Jul 14, 2009 · 5 posts
AnyMatter posted Tue, 14 July 2009 at 10:39 AM
hi!!!
i need some help??
where can i get a talk designer of xml format for toon boy sam??? does anyone knows??
ermm, i have mimic pro, but when i import SAM , his morph does'nt seems to work.
for an example, when i select the open lips, and adjust the strength, and clicked the preview at phoneme list, his lip doesnt open, even with maximum strength? any idea??? o maybe mimic pro doesnt support toon boy sam figure yet??
hope there's a reply, thanks
SAMS3D posted Tue, 14 July 2009 at 10:58 AM
Have you updated Talk Designer? A update came out a little while ago and I had the same issue, then I made sure all my updates were in place for Poser 7 and shut down after the updates and all worked. Sharen
kirwyn posted Tue, 14 July 2009 at 11:00 AM
I don't have Sam, but according to the Daz site, a custom Mimic .DMC file is included in the purchase. The use of this file should enable Sam to talk in Mimic.
AnyMatter posted Tue, 14 July 2009 at 6:05 PM
Quote - Have you updated Talk Designer? A update came out a little while ago and I had the same issue, then I made sure all my updates were in place for Poser 7 and shut down after the updates and all worked. Sharen
hi!!!
thanks for the reply!!! btw, how do i update talk designer??? is it just dowload the latest .zip file at
http://my.smithmicro.com/win/poser/updates.html??? do sam had xml file for lipsync in talk designer, instead of mimic pro??? where can i get his xml file..... :-) . thx
SAMS3D posted Wed, 15 July 2009 at 6:17 AM
You have to contact the makers of Talk Designer, the respond quickly, but usually, your updated Talk Designer should already be in your account. Just re-download and install. If you have questions, email the originators of Talk Designer and ask them about the update, like I said they will have an answer for you right away. Sharen
