Thu, Feb 27, 5:24 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: Particle Emitter revisited. C6P
Analog-X64 ( ) posted Sun, 19 July 2009 at 6:51 PM · edited Tue, 11 February 2025 at 2:08 AM
Ok a few years ago I posted that I was having problems with Plastic Spheres sinking into ground plane instead of bouncing around.  I thought this might be a bug in Carrara 5 pro.  Now I'm using Carrara 6 Pro and I still have the same problem.
Physicial Properties
Collide with other objects Checked.
Material: Plastic
Density: 1.100
Bounce: 70%
Friction: 10%
Spheres sink midway, I'm attaching image for reference.  I've tried tilting the ground plane to make some fall off which they do but some still stick and sink.
MarkBremmer ( ) posted Sun, 19 July 2009 at 7:23 PM
 Particles are "pretend" objects and don't actually exist. So, Carrara calculates the collisions based upon the hot points of replicated objects. The trick is to make an invisible object above the floor for the hot point to collide with.
Analog-X64 ( ) posted Sun, 19 July 2009 at 7:37 PM
Thanks.. I'll make another ground plane make it invisible and set it slightly higher than the visible one and see how it works.
Analog-X64 ( ) posted Fri, 24 July 2009 at 9:58 AM
ok... so the dilema now is that , I cant place any objects ontop of the ground plane without them looking like they are floating.. and if I make the gap between the visible and invisible plane, to little, the bottoms of the spheres start to look sinked in again.
I can turn off collision detection on the objects to be placed on the ground, but than the spheres dont bounce off them, and effect that I'm trying to achieve is lost.
I tried changing hotpoints on the particle generator and the ground plane and no luck.
MarkBremmer ( ) posted Fri, 24 July 2009 at 3:39 PM
 Since I'm not sure what kind of motion you are requiring, if you are running into issues with the particle emitter, you can instead use the replicator and convert into real objects. Just make sure to set the physical properties of the replicated object prior to converting.
These converted objects will respect other physical forces in the scene also.
Analog-X64 ( ) posted Fri, 24 July 2009 at 5:06 PM
Mark you are a genius!! :)
Ok I will try this and see how it works.  I just want to drop spheres, that as dropped interact with objects around by bouncing on and off of them.  Kind of like a rubber ball.
MarkBremmer ( ) posted Fri, 24 July 2009 at 5:15 PM
 This will do the trick then. :)
bwtr ( ) posted Fri, 24 July 2009 at 5:29 PM
Mark
I am missing some understanding about the replication idea/particles actions
Any chance of spelling it all out for my slow old brain please.
Brian.
bwtr
MarkBremmer ( ) posted Fri, 24 July 2009 at 5:44 PM
 Hi Brian,
The physical interaction of particles is different than other shapes in your scene when working with collisions. Carrara will correctly "bump" objects into one another for everything EXCEPT particles.
Particles are instantiated - that is, ghosts of the source object and are kept track of only by the hot point and nothing else. So, when particles collide with objects, all Carrara is tracking is the hot point, not the geometry. This results in the visible particles penetrating other objects in the scene up until the hot point collides with another object.
Mark
bwtr ( ) posted Fri, 24 July 2009 at 9:16 PM
Hi Mark
Sorry if I am having a thick day--again.
OK. the particles can be changed into objects--say spheres.
But, where does the Replicator idea integrate into that please?
(Unless you are only saying the number of emitters can be increased by the Replicators?)
Brian
bwtr
MarkBremmer ( ) posted Fri, 24 July 2009 at 11:09 PM
 No worries. The Replicator, unlike the particle emitter, allows you to convert the replicated objects into actual geometry. Then the real geometry acts like any other geometry and responds to collisions correctly.
Analog-X64 ( ) posted Fri, 24 July 2009 at 11:14 PM
Marks explanation make perfect sense.
If my scene only had the Ground Plane and Particles falling onto it, I could simply do the trick he suggested in earlier posts, where I create another plane but make it invisible.  The Particles will fall through the invisible plane partially and will look as if they are ontop of the solid plane.
Since I have other objects in the scene the particles will not interact with I need to utilize the method of converted objects.
I just got back from a concert and its late at night I will try this method and report later :)
bwtr ( ) posted Sat, 25 July 2009 at 1:57 AM
Is this what is meant? I have the replicator set at 1. Brian
bwtr
Analog-X64 ( ) posted Sat, 25 July 2009 at 7:47 AM
  • If the Replicator is the Parent and the Particle Emitter is the child than I get a mess because the particle generator itself is replicated.
  • If the Particle Emitter is the Parent and the Replicator is the child nothing changes spheres still sink.
I must be missing something.
Analog-X64 ( ) posted Sat, 25 July 2009 at 8:00 AM
I was looking at Brians example and I see a sphere, where did that sphere come from?
bwtr ( ) posted Sat, 25 July 2009 at 7:36 PM · edited Sat, 25 July 2009 at 7:38 PM
In the advanced (second tag) down in the lower LH corner of the Particles workings is where you access a "real" object rather than a particle. I used the standard Sphere at 1.00 size I think?
BUT--- I still can not work out why I need the Replicator and neither, in the replicator mode, how to stop the sinking into the ground?
And I had the Replicator as only 1 therefore no "mess"!
Brian
bwtr
Analog-X64 ( ) posted Sat, 25 July 2009 at 9:18 PM · edited Sat, 25 July 2009 at 9:22 PM
Thanks for the info Brian, and yes I've got the same results as you did.
I've been playing with different variations and settings.
This is what I tried.
Particle Emitter -> Basic -> Shape -> Objects
Advanced -> Replicated Objects -> Replicator
I also added a sphere to the Replicator.
Oh and also created a converted replicator, which changed
the behaviour of the particles bouncing everywhere but still sinking problem.
Same thing the replicated Spheres are sinking.
Another description of what I'm trying to achieve is to create the effect of droping a bucket of tennis balls onto a floor.  The balls simply bounce around everywhere and eventually rest/stop moving.
