Subject: Force "Use Limits" on in .cr2 or pose
papillon68 opened this issue on Jul 25, 2009 · 7 posts
papillon68 posted Sat, 25 July 2009 at 6:16 AM
Hi, any way to trigger the figure option "Use Limits" alway on for a certain character or pose, so that the user doesn't have to go through the menu and trigger it manually ? Thanks
visit my blog:  www.alessandromastronardi.com
My Rendo Store
lisarichie posted Sat, 25 July 2009 at 7:58 AM
Create a copy of the original .cr2 file.
Open the copy .cr2 in a text editor, I use Notepad ++,  change  forceLimits 0 to forceLimits 1 and save the file.
Test this revised .cr2 in Poser, the limits applied to the parameter dials should now be recognized.
If everything works properly replace the original .cr2 file with the revised edition. I keep the original in an archive just to be on the safe side.
There is some discussion on the non-zero value  to use (1-4) but I haven't noticed it making a difference so I just change it to 1, nothing has exploded......yet.
ockham posted Sat, 25 July 2009 at 8:39 AM
I'm pretty sure the 1 versus 4 difference was an urban legend, or possibly
true for some unusual circumstance.  I confess to helping spread the myth,
because I thought I saw the difference.
As far as I can tell (tested carefully in both P4 and P7 right now) the value 1 will
always force the limits regardless of the setting of Figure: Use Limits.
More precisely, when forceLimits is 0, the figure:UseLimits setting matters.
When forceLimits has a*ny nonzero value, *the limits are solid.  So 4 won't
make anything explode, but it's no different from 1.
My python page
My ShareCG freebies
lisarichie posted Sat, 25 July 2009 at 8:56 AM
Ironically DAZ studio will recognize the force limits set on a parameter dial in Poser figures without having to edit the .cr2.....bringing us to: WTF are Poser devs thinking?
Astoundingly blind to require manual editing to activate a parameter value that was set within the native application originally.
papillon68 posted Sat, 25 July 2009 at 10:21 AM
Well, thank you very much for these precious advices guys !
My Rendo Store
lesbentley posted Sat, 25 July 2009 at 9:16 PM
You can also use a pose file to force limits, eg: {
version
        number 3.0
actor head
        channels
                targetGeom RoundFace
                        forceLimits 1
The pose can also set the 'min' and 'max' value of the limits, eg: {
version
        number 3.0
actor head
        channels
                rotateY yrot
                        forceLimits 1
                        min -35
                        max 35
lesbentley posted Sat, 25 July 2009 at 9:37 PM
For P5 and up, you can also make a generic pose file that will force limits on the selected actor, by using "actor $CURRENT", eg: {
version
        number 5
actor $CURRENT
        channels
                targetGeom PBMCC_04
                        forceLimits 1
                        min -0
                        max 1
                rotateX xrot
                        forceLimits 1
                rotateY yrot
                        forceLimits 1
                rotateZ zrot
                        forceLimits 1
