chaylastorm opened this issue on Jul 25, 2009 · 7 posts
chaylastorm posted Sat, 25 July 2009 at 7:16 PM
I now have Poser 7, but still have Poser 6 on computer (mac os x). Now from what I gather..... I have to get rid of Poser 6?..... Before I get rid of all that I have there and reload into Poser 7, just thought I would check with someone who may know.
Also I can't seem to be able to get my textures working. I have tried both in Poser 6 and 7, could one be cancelling out the other? I used to be able to get my texture to work in Poser 6... before I loaded Poser 7. These are textures I am making ... not bought ones.
I would be grateful for any help in any way with these questions, or if someone knows where I can look it up.
Thanks a lot.
IsaoShi posted Sat, 25 July 2009 at 7:31 PM
You don't need to uninstall Poser 6 at all. You can have them installed alongside one another, since they are in different Applications folders. They will also use separate preferences files, in your
If you have lots of content in the Poser 6 main Runtime, you can create a new Library in Poser 7 and point it to the Applications/Poser 6 folder, and all that content will be available to Poser 7.
The only problem with this might be if you install Poser 7 SR3 (which I would strongly advise you do) then you might get some problems due to duplicated content files across the two Runtimes. In this case, it may be better to create a completely new external runtime for Poser 7 and transfer old content across to it as required, without creating duplicates.
what I should be."
Murakami)
chaylastorm posted Sat, 25 July 2009 at 7:42 PM
Yes.. I think that might be by problem (cross talking?). I have a spare H.D. maybe I should put one of them on that. I'lI clear out all of Poser 7 and put it on the H.D. and see what happens then. I know that before I had P.7, I had no trouble getting my textures to work. Guess I'll just go back to 'old faithful P6. LOL
Thanks for answering so quickly
thefixer posted Sun, 26 July 2009 at 2:57 AM
I have poser 6 and 7 running fine on the one HD, Poser 7 shares poser 6's runtime with no problems!
Injustice will be avenged.
Cofiwch Dryweryn.
IsaoShi posted Sun, 26 July 2009 at 3:29 AM
thefixer: did you install SR3 for Poser 7? As far as I recall, duplicate content files did not cause any problems before this update.
what I should be."
Murakami)
thefixer posted Sun, 26 July 2009 at 3:35 AM
Yes I have SR3 installed.
I use Poser 7 but use the Poser 6 runtime from inside Poser 7, never had an issue.
I run on Vista 64 ultimate if that helps.
Cofiwch Dryweryn.
chaylastorm posted Sun, 26 July 2009 at 3:40 AM
No... I have only uploaded the Poser 7 disc I got from SmithMicro.
