Forum: DAZ|Studio
Subject: DS 3 install content
blueblott opened this issue on Jul 28, 2009 · 10 posts
blueblott posted Tue, 28 July 2009 at 2:14 AM
**Hey,
I have the new DazStudio 3 (free) version but loading content (Native)
just is not happening for me ??
I can create my Poser runtimes ....no trouble at all and they all work just fine.
When it comes to Daz content its hopeless .
The installer is given the correct path to the location  it completes the install as being successful....end of story no trace..
So cannot import through manager as I did with my Runtimes.
What is the correct path now like c:program filesdaz3d
or is it c:program filesdazstudiocontent  as it used to be?
Never had this problem with any of the previous versions
Can any one help please?
TheHalfdragon posted Tue, 28 July 2009 at 2:22 AM
k just looked on my hdd and i have it c:program filesDAZ 3DDazStudio3content .  hope that helps and there is or might be a daz3d or another folder with similar name that shows up in your content tab that they may be under
Avros posted Tue, 28 July 2009 at 2:57 AM
Have a look if you have two content directories for DAZ {eg: DAZ/studio/contents/ , DAZ/studio3/contents/} ...
You may not be searching the correct directory. You can add them from the Preferences Tab.
Example of how my directories are listed in the Preferences Directories Tab.
Daz Studio Formats:
DAZ/Studio3/contents/
DAZ/Studio/contents/shader mixer presets/presets/
Poser Formats:
Other Supported Formats:
RHaseltine posted Tue, 28 July 2009 at 8:42 AM
Content should not go into the application folder, especially not On Windows Vista or Windows 7 where the OS may be obstructive if you try. By default, if you don't have other directories already set up, DS 3 will put the default content folder in your Documents folder and will also use a folder in the User folder for some of the core files (which includes some of the new shaders, which really shouldn't be there).
blueblott posted Tue, 28 July 2009 at 10:00 PM
Many thanks to you all for your help.
Would I be able to keep all my content files Poser Runtimes and DazStudio files on a partition as I have sliced my hdd in two?
(Plenty of storage space)
Leaving the Daz3D app on my C: drive.
I am not all that keen on using Documents for my content folders.
Have developed the trait of using Documents for a temp holding area not as an archive . But I see what you mean
Will experiment
Thankyou.
RHaseltine posted Wed, 29 July 2009 at 9:09 AM
That should be fine - I put most of my third-party content in categorised content folders on my D: drive, with my own files in the folder in my documents folder on E: and the application on C:.
TheHalfdragon posted Wed, 29 July 2009 at 9:38 AM
i haven't had a problem with it almost all my content is on my G: drive and my daz is on my C: drive
blueblott posted Wed, 29 July 2009 at 11:47 PM
Thanks for that , that will make things very tidy and compact.
Thankyou for your help.
Magick_Lady posted Sun, 02 August 2009 at 9:24 AM
I let the application do a search and then everything shows up
  q
blueblott posted Sun, 02 August 2009 at 8:56 PM
Thankyou Magic_Lady
Have been there done that !....lol.
It is all a challenge but when things go right ... wow...what a Boost !
Thankyou kindly for your advice.
Regards  Blueblott.
