binhotinto opened this issue on Jul 28, 2009 · 4 posts
binhotinto posted Tue, 28 July 2009 at 8:45 AM
I'm having some problems creating a prop in dazstudio. I've done exacly as this tutorial says, but when I save the file in the props folder, It only creates the .daz and .png files, and when I go to dazstudio try the prop I can see the new folder but theres nothing inside of it :
I also did the same thing with poser, and creates the .png and .pp2 files, and if I cut this and paste in the daz porps folder, them I can open them in dazstudio, the strange thing is that i dont have a geometry file, can .pp2 files work without the geometry file? I've opened the .pp2 with notepad and the only files there are the textures.
mishamcm posted Tue, 28 July 2009 at 9:06 AM
You need ti save it in the DS-format content folder, not the Poser-format runtimelibraryprops folder. DS script files (.ds/.dsb/.dsa/.dse) are only visible in the Poser-format runtime if there is a Poser file of the same name, in which case the script is run instead of the Poser file. DS-format scene files (.daz) aren't visible in the Poser--format runtime at all.
// Load a scene file instead of a Poser file
if ( getArguments().length != 0 ) {
var sourceName = getArguments()[ 0 ];
var periodPos = sourceName.findRev( "." );
if ( periodPos != -1) {
sourceName = sourceName.left( periodPos ) + ".daz";
App.getContentMgr().openNativeFile( sourceName , true );
When you click on the .pp2 in DS (in DS3 there'll be a scroll in the upper left corner of the icon to let you know there's a .ds file there), the .ds file is executed, which loads the .daz file.
mishamcm posted Tue, 28 July 2009 at 9:07 AM
As for geometries, .pp2 files can call an external geometry .obj or they can contain the geometry internally.
binhotinto posted Tue, 28 July 2009 at 10:29 AM
Quote - As for geometries, .pp2 files can call an external geometry .obj or they can contain the geometry internally.
Thanks for the help, I think i'm going to use only the .pp2 file since it works on both dazstudio and poser.
