mhscspo opened this issue on Jul 28, 2009 · 10 posts
mhscspo posted Tue, 28 July 2009 at 7:41 PM
sparrownightmare posted Tue, 28 July 2009 at 7:48 PM
That depends on if you just used a cube primative or a spline or vertex object. I try and stay away from primatives. For something like this I just use a simple spline object so I have different shading domains. Each domain can have a different texture, or you can use one master texture for all of the domains.
bwtr posted Tue, 28 July 2009 at 7:58 PM
Should not Primatives or whatever be fine?
For the top item on the shader tree sellect Projection Mapping>Flat Mapping
(Refer the Help Manual)
(Or am I missing something?--again!)
Brian
bwtr
mhscspo posted Tue, 28 July 2009 at 9:17 PM
Ok, I'm using a primitive in this example but I guess I'm not too familiar with adding textures to more than one side of an object, I did use the flat mapping to do the front of the cube as seen in the picture, but I just couldn't get the top and sides. Exactly what are the steps to be taken in order to achieve this? I'll try and see if I can do it with a vertex object as well.
pauljs75 posted Tue, 28 July 2009 at 11:37 PM
Also if the cube is created in the modeling room instead of the primitives from the assemble room, you may have more than one shading domain.
Oh, wait a sec. You want different textures on each side.
You could use a modeling room cube and go by shader domains. Or... You could go to set the top shader to complex>layers list or multi-channel mixer. Then in the additional layers, set the flat mapping to pick different faces for each texture set.
bwtr posted Wed, 29 July 2009 at 8:27 PM
No.
You just use the Flat Mapping and apply a different shader to each side!
Simple
)Brian
bwtr
bwtr posted Wed, 29 July 2009 at 8:46 PM
bwtr
mhscspo posted Wed, 29 July 2009 at 10:18 PM
Quote - Hope this explains.
Brian
Thanks very much I've got it now..
pauljs75 posted Sat, 01 August 2009 at 3:43 PM
Layers list works just the same though. I don't think there really is a right or wrong way, as long as the end result is what you're wanting.
mhscspo posted Sat, 01 August 2009 at 11:42 PM
Quote - Oh, I see. Didn't realize flat mapping was a top shader option. Still, even with that you have to add a flat-mapping channel to each subset on the tree.
Thanks....
