speedgoat opened this issue on Jul 29, 2009 · 7 posts
speedgoat posted Wed, 29 July 2009 at 10:48 AM
Hi
Is it possible to show or hide conformed clothing or props in a certain frame during an animation?
Thanks!
MistyLaraCarrara posted Wed, 29 July 2009 at 11:33 AM
Hi. Next to the 'visible' checkbox on the properties tab, there is a key symbol.
Click it toggle the animation parameter.
I think. My memory is shot today. I used to be able to picture the GUIs in my mind.
sigh, pesky ketones.
Cage posted Wed, 29 July 2009 at 2:49 PM
I thought the 'visible' check applied a global setting, which will be in effect from the start to the finish of an animated sequence. To make something appear in the course of an animation, you probably need to use some tricks with scaling, translation, or animated transparency effects in the materials set up for the item in question. Or render two or more animated sequences and composite them in some video editing software.
Scaling or translating a conformed garment might not work well, if at all, unfortunately....
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
MistyLaraCarrara posted Wed, 29 July 2009 at 4:13 PM
anything that has a key symbol next to it, can be toggled for animation.
nruddock posted Wed, 29 July 2009 at 5:20 PM
Quote - I thought the 'visible' check applied a global setting, which will be in effect from the start to the finish of an animated sequence. To make something appear in the course of an animation, you probably need to use some tricks with scaling, translation, or animated transparency effects in the materials set up for the item in question. Or render two or more animated sequences and composite them in some video editing software.
Animating Visibility was a new feature in P7.
Cage posted Wed, 29 July 2009 at 5:43 PM
D'Oh! It's been added in P7? Well... huzzah! With a added. Ahem. I've had P7 for over a year, and still didn't know this had been added. Hurm.
Umm. My apologies....
speedgoat posted Thu, 30 July 2009 at 6:11 AM
Thank you all, you make my day :))
