uncle808us opened this issue on Jul 31, 2009 · 8 posts
uncle808us posted Fri, 31 July 2009 at 9:23 AM
MacBook Pro OSX El Capitan Ver 10.11.6
Mazak posted Fri, 31 July 2009 at 9:49 AM
Your object is hidden. Click with the mouse on the X and you will see the object again.
Mazak
uncle808us posted Fri, 31 July 2009 at 9:57 AM
Quote - Your object is hidden. Click with the mouse on the X and you will see the object again.
Mazak
Did that still no oblect and the X remains there.
Mazak posted Fri, 31 July 2009 at 10:09 AM
Mazak
Mazak posted Fri, 31 July 2009 at 10:12 AM
Can you import your obj in an other application? Maybe the file is corrupt and need re-save.
Mazak
uncle808us posted Fri, 31 July 2009 at 10:26 AM
Quote - Can you import your obj in an other application? Maybe the file is corrupt and need re-save.
Mazak
That was the problem.
ShawnDriscoll posted Sat, 01 August 2009 at 4:03 AM
Also watch out for n-gons in your OBJ models. Vue will abort importing if there are enough of them. Groupings from Lightwave OBJ exports will hiccup Vue too.
uncle808us posted Sat, 01 August 2009 at 10:27 AM
Good tip thanks. I try for all triangles.
