Marque opened this issue on Aug 01, 2009 · 7 posts
Marque posted Sat, 01 August 2009 at 7:53 PM
JenX posted Sat, 01 August 2009 at 8:05 PM
That is weird! Did you do anything special before posing her? Did you try restarting Poser/your system?
Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
pjz99 posted Sat, 01 August 2009 at 8:06 PM
Does this happen with every CR2? Does this happen with the DAZ-installed original CR2? Does this happen when you stop/restart Poser? If you are in the Poser 8 beta program, is this a machine on which Poser 8 is co-installed?
ockham posted Sat, 01 August 2009 at 8:06 PM
If it just started, most likely culprit is video card / Open GL problems.
I recall Windows ran an automatic update a couple of days ago,
and those updates often screw up video drivers.
pjz99 posted Sat, 01 August 2009 at 9:05 PM
One more question, does this happen with all poses, e.g. the DAZ default ones supplied with V4?
Little_Dragon posted Sat, 01 August 2009 at 9:36 PM
Check to see if "Bend Body Parts" is disabled for some reason.
Display menu --> Bend Body Parts
Marque posted Sun, 02 August 2009 at 4:26 AM
Little_Dragon nailed it. Thanks all for the suggestions, much appreciated!
