Subject: Poser 7 preview display error
MocPac opened this issue on Aug 03, 2009 · 15 posts
MocPac posted Mon, 03 August 2009 at 3:12 PM
I'm not sure how to explain this, so I provided a photo on what my problem is...
Does any know how to fix this problem with the skin through the clothing and the teeth poking through the mouth?
IsaoShi posted Mon, 03 August 2009 at 3:22 PM
Increase the "hither" distance on the camera parameters.
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
MocPac posted Mon, 03 August 2009 at 4:01 PM
Yeah, I'm still getting the same problem.
IsaoShi posted Mon, 03 August 2009 at 4:07 PM
Hmm... that always fixes it for me.
Are you sure you are changing the hither parameter for the correct camera? It is possible to have one camera selected while viewing with another.
MocPac posted Mon, 03 August 2009 at 4:14 PM
Yeah. It helps a little with the teeth but the clothing still suffers from the same problem.
IsaoShi posted Mon, 03 August 2009 at 4:27 PM
Oh, wait a mo'... that view is the Front camera, I think, not (as I assumed) the Main camera.
I can never completely eliminate preview poke through on the orthographic cameras. Reducing the yon distance to zero is the best I can get.
MocPac posted Mon, 03 August 2009 at 4:33 PM
I'm not sure whats wrong. It does this to all camera angels. Its only normal when I zoom in closely. It started to do this once I reinstalled my poser. I remember fixing this problem before, but I forgot exactly what I did to fix it.
IsaoShi posted Mon, 03 August 2009 at 4:33 PM
By the way, you know this is only in the Preview? It will render okay.
MocPac posted Mon, 03 August 2009 at 4:37 PM
Yeah. It just gets annoying when I try to add clothing.
IsaoShi posted Mon, 03 August 2009 at 4:37 PM
Quote - I'm not sure whats wrong. It does this to all camera angels. Its only normal when I zoom in closely. It started to do this once I reinstalled my poser. I remember fixing this problem before, but I forgot exactly what I did to fix it.
This will be the same using any of the orthographic cameras (Front, Right, Left, Back, Top, Bottom).
Have you tried using the Main camera? It should be fine if you just increase the hither distance.
MocPac posted Mon, 03 August 2009 at 4:41 PM
Quote - > Quote - I'm not sure whats wrong. It does this to all camera angels. Its only normal when I zoom in closely. It started to do this once I reinstalled my poser. I remember fixing this problem before, but I forgot exactly what I did to fix it.
Yeah. It does this to all camera angels. I have to zoom in close to make sure the clothing is adjusted properly.
IsaoShi posted Mon, 03 August 2009 at 5:47 PM
Sorry to be a nag about this (I'm just trying to help, honest!)  but you did not say whether you tried using the Main camera. You only said "all camera angles". Did you really mean "all cameras"?
The symptoms you describe are exactly the same for me with all orthographic cameras, but not if I use the Main camera. With the Main camera (and the other perspective cameras, such as Dolly, Posing and Face) increasing the hither distance always solves the problem for me.
Sorry again to press you, I just want to make sure we're covering "all angels" (without wings)!
MocPac posted Mon, 03 August 2009 at 6:02 PM
lol - Sorry. Yeah, I tried using the Main Camera angel and it still does the same thing.
Its basically the same thing on all camera angels, but it appears somewhat normal when you zoom in close.
The picture on the right (on the picture that I posted), is taken from the main camera angel. If you look on the right bra strap, you can see the problem is still there, but its not as bad as when you zoom out with the camera.
ratscloset posted Tue, 04 August 2009 at 12:49 AM
What are the settings for the Camera and what Platform?
ratscloset
aka John
IsaoShi posted Tue, 04 August 2009 at 8:33 AM
Quote - The picture on the right (on the picture that I posted), is taken from the main camera angel.
Huh? The picture on the right is taken with the Face Camera, not the Main Camera. It says so in your screenshot. I don't know what you mean by "main camera angle". The important thing is which camera you are viewing with (as stated in the Document window) and making sure you are adjusting the parameter dials for the same camera.
But anyway, it seems this is a problem for you on all cameras, so I really don't know what's causing it... sorry.
