Forum: Vue
Subject: Need Camera animation help
atheistnation opened this issue on Aug 09, 2009 · 5 posts
atheistnation posted Sun, 09 August 2009 at 12:29 AM
 Im still learning Vue and im trying to make a scene where the camera starts underground and moves up through the plain and shows the whole area. but I cant get my camera to animate up or down. it'll only go side to side or front to back. what do i need to do?
Thanks
wabe posted Sun, 09 August 2009 at 2:43 AM
I think you have to unlock the camera height. It is in the upper right attribute window when you have selected the camera.
atheistnation posted Sun, 09 August 2009 at 5:33 PM
 I dont know if this matters but im using pioneer and I dont see anything in the attributes section about unlocking the camera. I have everything set up i just cant get the camera to animate moving up or down.
A-Spot posted Tue, 11 August 2009 at 11:04 AM
Left of the Height value box up in the camera properties, there is a padlock (right?) inside a yellow box. Click it, and the padlock should now be gray and not inside a yellow box. The "fixed-distance-from-objects-below" lock is now off. Generally, I work with this OFF all the time,except for when working close to bumpy mountains and displaced water. Other than that, I disable it as soon as I start working on my scene.
I think this counts for every Vue version with the camera lock built in...
Cheers,
Thomas / A-Spot
atheistnation posted Tue, 11 August 2009 at 3:05 PM
 Thanks
