sanbie opened this issue on Aug 10, 2009 · 11 posts
sanbie posted Mon, 10 August 2009 at 2:40 PM
This is what comes up everytime I install it...
TrekkieGrrrl posted Mon, 10 August 2009 at 2:44 PM
Looks to me like the file didn't download correctly.
The filesize should be 625 MB (655.980.276 byte)
sanbie posted Mon, 10 August 2009 at 2:53 PM
Yep that's the size and I have now downloaded it 3 times...Still it does the same thing..
Sanbie
Lucifer_The_Dark posted Mon, 10 August 2009 at 2:56 PM
I bet you're trying to run it on Vista, right click the icon & run as administrator, that fixed it for me.
Windows 7 64Bit
Poser Pro 2010 SR1
Gareee posted Mon, 10 August 2009 at 2:56 PM
Hmmm maybe right click run the installer as administrator, or make sure UAC is turned OFF if you are on vista? (google that, and you'll find complete instructions.)
sanbie posted Mon, 10 August 2009 at 3:00 PM
No I am running XP pro ...This is driving me nuts...
bagginsbill posted Mon, 10 August 2009 at 3:24 PM
When you re-installed, how did you answer the question about what to do with the existing configuration files?
jdcooke posted Mon, 10 August 2009 at 3:25 PM
If you haven't install the lastest Microsoft C++ runtime, you can try downloading and installing the latest from Microsoft, found here:
www.microsoft.com/downloads/details.aspx
Because the application runs in Vista, your copy of XP may require this runtime to be installed for the application to run correctly.
good luck
sanbie posted Mon, 10 August 2009 at 3:44 PM
You little beauty jdcooke...that did the trick!!
Thank You Thank You Thank You
jdcooke posted Mon, 10 August 2009 at 4:52 PM
Cool
jimmy1 posted Wed, 12 August 2009 at 10:42 PM
Yes, thanks -- that did it for me too.
