Forum: Carrara
Subject: Carrara 7 standard problem
uncle808us opened this issue on Aug 12, 2009 · 5 posts
uncle808us posted Wed, 12 August 2009 at 11:16 AM
I have Carrara 6.2 and in it there are objects lots of them. But I also have Carrara 7 standard. in it there are leaves only. Where are all the objects?
I am pretty sure I have downloaded all the Carrara 7 standard files.
Thanks for the help in advance.
MacBook Pro OSX El Capitan Ver 10.11.6
MarkBremmer posted Wed, 12 August 2009 at 11:26 AM
 There is the Carrara 7 Application download and the Carrara 7 Content download. It sounds like you have one download left to do.
Mark
uncle808us posted Wed, 12 August 2009 at 1:08 PM
I downloaded again Carrara 7 Native Content but still nothing there.
MarkBremmer posted Wed, 12 August 2009 at 1:53 PM
 Funky. The installer should put it in the correct location unless you've chosen a different location to install Carrara. You may want to confirm the install location.
Also, if you've located the Content in another directory, you can use the little document icon in the upper right corner of the Browser and link to it.
uncle808us posted Wed, 12 August 2009 at 3:13 PM
I found it thanks.
