Believable3D opened this issue on Aug 13, 2009 · 61 posts
Believable3D posted Thu, 13 August 2009 at 5:28 PM
I fought Poser Pro for months because whenever my character had a closed mouth, she ended up with a long black line all along her mouth opening is I used raytraced shadows. Horrible.
My first renders with P8, I didn't pick up on it, because I had the mouth just slightly open. But the problem is still here. See attached image. Keep in mind that the settings for the image below were very high.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
Believable3D posted Thu, 13 August 2009 at 5:30 PM
Is anyone else experiencing these problems with raytracing? If not, any idea why I would be?
P.S. Please forgive the bump map; it still needs some serious work.
______________
IsaoShi posted Thu, 13 August 2009 at 6:26 PM
There are more differences - ears, nostrils, eyelid creases, eyewhites.
Did you use material-based AO for the first render?
And did you switch off raytracing for the second one? (I know you said same render settings... just checking!)
Could that be the difference, rather than the type of shadow you are using? Not sure....
what I should be."
Murakami)
Believable3D posted Thu, 13 August 2009 at 6:34 PM
Like I said: all other settings are exactly the same. I changed nothing except raytracing > depth-mapped shadows on the lights.
The other artifacts - not so good, but not as glaring as the lips.
I'm just checking something right now though... I think I may have AO on the lips. The shader was originally built on the AO version of VSS. I scrapped it for the skin, but may have forgotten the lips. I'm doing a test render with a non-AO VSS version right now to see what happens.
I don't recall... is AO only a problem with raytracing? It was these problems that led me to abandon raytraced shadows in Poser Pro, but now that I can rid of material AO, maybe I'll be (relatively) okay after all.
______________
Believable3D posted Thu, 13 August 2009 at 6:39 PM
______________
pjz99 posted Thu, 13 August 2009 at 8:16 PM
Where exactl are your lights and how are they set? You have several weird things going on, e.g. the nostril has a really sharp transition (probably AO there, turn it off). The eyebrows also went strange in your last render.
Believable3D posted Thu, 13 August 2009 at 8:37 PM
PJZ, in the last image, there is definitely no AO, since I used Bagginsbill's no-AO VSS shader straight out of the box for that render. That's what I was testing, to make sure the problem wasn't material-based AO that I had missed cleaning up.
As far as the eyebrows going strange and the general redness - I didn't adjust anything in the shader or my render settings either. Since BB's shader has GC built in, and I was using HSV, there's a bit of blowout. (That explains the artifact turning red. Well, sort of, but not. I wouldn't have expected the artifacts to change colour to that degree.)
I've got another render going so can't give you details on the lights, but basically they're very simple. I think I've got two, one angled from the left and one from the right. I believe shadow softness is set somewhere around 4 degrees.
Thanks.
______________
pjz99 posted Thu, 13 August 2009 at 8:50 PM
Is that sharp line in the nostril painted into the texture? Those hot spots on the eyes, are those painted in as well or are they coming from a proper reflection (not really to do with your question but I'd like to know)?
Something is wonky with how your lights are set, it appears to me that either you don't have shadows turned on for all lights or you're using depth mapped shadows - at the edge of the ear there is a break in the shadow that really should not be there. You also don't seem to have shadow min bias turned down low enough as the eyelashes are not casting a shadow, and they should.
Believable3D posted Thu, 13 August 2009 at 8:52 PM
I should also add that I have experienced this phenomenon with a wide variety of lighting angles and setups in the past. Again, this is why I had pretty much abandoned RT lighting in Poser Pro. I'm disappointed to see that things really haven't improved in P8 on this front.
______________
pjz99 posted Thu, 13 August 2009 at 8:53 PM
Where are your lights?
Believable3D posted Thu, 13 August 2009 at 10:00 PM
The settings are as I have said. When I say that I'm using raytracing, that's what I'm using for lights (images 1 and 3). Shadows are on.
The bias issue did occur to me. (IIRC, with the file above, the setting is left at the default 0.8.) However, I had read that going for quality setting with bias actually makes artifacts worse. So I fired up Poser Pro, created a new scene, and tried a raytraced light render with the Shadow Min Bias cranked way up on both lights. The result is much better - tho still bad, and the shading in the ear is terrible. Keep in mind that this is not the same scene, but I can easily reproduce the lip problem in render after render with varying settings, as I noted. This one has two infinites, one set way off to her left the other from a closer angle to her right.
In answer to your question about the eye colour map - there are two relatively small highlights in the irises. I should probably take them out; the larger of them is visible in the renders above (it's to the upper left of the iris).
______________
Believable3D posted Thu, 13 August 2009 at 10:05 PM
I'm not sure what you're talking about re sharp line in her nostril, unless you really mean, on the side of her nose just above her nostril. Most of the wonky looking lines you see are from a bad bump map (hence my P.S. in the second post).
______________
pjz99 posted Thu, 13 August 2009 at 10:17 PM
Quote - This one has two infinites...
That would be your problem. Do you have two suns in the scene lighting your character? Use spotlights or point lights. I don't think infinite raytraced shadows work with blur. Infinite lights imo really should be used for just one thing in a render: simulating very distant, very large light sources like the sun.
Believable3D posted Thu, 13 August 2009 at 10:26 PM
Thanks!
Duh. I don't usually have two infinites (at least, not anymore; I'm sure I did numerous times before I got more specific with lighting) when I create a real scene. But Poser loads three infinites by default, and when I'm doing character work I don't play much with lights, usually.
Am going to turn one of these into a spot and see what happens.
(BTW: I turned min bias way down to 0 just to see what would happen. Ouch.)
______________
pjz99 posted Thu, 13 August 2009 at 10:36 PM
If this is indoor, you shouldn't have ANY infinite lights.
You can set up lights, render settings, default scene contents however you care to, and in Edit -> General Preferences you can "Set Preferred State", and that will be your new default.
edit: just to make something perfectly clear, what you're seeing is not an "artifact", it's simply a shadow.
Believable3D posted Thu, 13 August 2009 at 10:51 PM
Mind you, this is a Poser Pro render... so still crossing my fingers it's fixed in Poser 8.
______________
Believable3D posted Thu, 13 August 2009 at 10:56 PM
Never thought about resetting my prefs. That's a good idea.
But on your claim that's not an artifact, but a shadow.. sorry, I'm not buying. It's a shadow in the same way that the nasty blotches in other darkened places are shadows, sure. But if they are that bad of shadows at high Q settings, I'd call them artifacts. There is no way a shadow should be a solid line like that. Not on an organic surface like the lips. It looks very bad. I could draw in a shadow like that with a permanent marker. (And note, I have a shadow blur radius of close to 5 on both lights in the render I just posted.)
______________
Believable3D posted Thu, 13 August 2009 at 11:15 PM
I'm beginning to think that my problem is quite unique, however. I'm sure you would know what I was talking about it you had experienced this, and I don't see similar complaints from elsewhere.
Hm. I better doublecheck my subversion too. Edit: No, that can't be the problem, as I'm getting it in P8, too, and I'm obviously up to date (incl. hotfix).
______________
Believable3D posted Fri, 14 August 2009 at 10:13 PM
I'm stumped. And I can't figure out why I seem to be the only one with this problem.
______________
pjz99 posted Fri, 14 August 2009 at 10:25 PM
It's a shadow. Really.
Believable3D posted Fri, 14 August 2009 at 10:54 PM
You saw it above. It is impossible for a shadow - at least, of any quality whatsoever - to be generated like that when the lights are directly in front of the face. Or anywhere else for that matter. And it looks just this ugly, like drawn by a big felt marker, no matter how soft the shadows are set in the lights. And it doesn't happen with DM shadows. If it was a reasonable RT shadow, it would be the same general placement as the DM shadows. But the DM shadow is minimal, nothing like that at all.
______________
stewer posted Sat, 15 August 2009 at 12:51 AM
Don't do 0 for shadow bias, that won't work. Try 0.1 or 0.05, then things should look a lot better.
Believable3D posted Sat, 15 August 2009 at 12:57 AM
Thanks, Stewer. This happens whether shadow bias is at the default 0.8 or wherever I seem to adjust to. I'll try those settings though.
______________
Believable3D posted Sat, 15 August 2009 at 1:05 AM
I should add: none of the renders shown here were of min bias at 0. That one was creating other sorts of artifacts (lines in the skin); I didn't bother posting it.
______________
Believable3D posted Sat, 15 August 2009 at 1:50 AM
It's a mystery to me why lights load a .8 min bias by default. Wish there was a way to set that in General Preferences. (I do now have the lights in Preferred State set at .05, but that doesn't look after any new lights I add to a new scene.)
______________
ice-boy posted Sat, 15 August 2009 at 1:58 AM
Quote - Here's the very same image and render settings with depth-mapped shadows. No problem at all (and rendered in 2/3 the time, consistent with results elsewhere; not really a surprise).
no problem at all in that render?
my dear friend you have:
a) no shadows. that would explain why i dont see any shadows
b) small shadow map. this would explain why i dont see any shadow map . is its to smal lthen it gets so blury that you dont see it.
whats important with shadows is that the closer something is to an object the more sharper the shadow gets. this is why raytraced shadows are physical correct. of course with RT spotlights we can not do very soft shadows. to bad.
Believable3D posted Sat, 15 August 2009 at 2:42 AM
I always have shadows on. Sure, the depth maps were small. But if the proper render was a line at the lips like that, you still woud have seen it with DM shadows.
I'm triggering some sort of bug with raytraced lights. Only using a narrow window of min bias works to get rid of it, as demonstrated already in my previous post. If that ugly black line was "normal," improving the quality of the min bias wouldn't virtually get rid of it. It's not simply ugly. It's not normal. It is not physically correct. It's not correct in any sense. It's a glitch.
______________
TrekkieGrrrl posted Sat, 15 August 2009 at 3:05 AM
The lips are completely closed in your render, right? What happens if you open them juuuust a smidgeon? I have a feeling it's some self-shadowing thing going on here. Not sure, but as you say, your problem is unique.
Then again I'm not sure there's really a problem here... I mean.. I just looked at my own mouth in a mirror and the line between my lips are definitely BLACK. And that was in a fairly shadowless environment (overcast and only natural light)
Also what does it look like if you render her with only indirect light? (from a lightbox or similar?)
Believable3D posted Sat, 15 August 2009 at 3:13 AM
______________
Believable3D posted Sat, 15 August 2009 at 3:17 AM
TrekkieGrrrl, sure your lip join is black. But it's not abrupt, nor is it a big thick line. It's a thin dark line, with gradient shadow going toward it.
In most of the renders, the mouth was absolutely closed. I've had the same thing with it just slightly open, as well.
______________
pjz99 posted Sat, 15 August 2009 at 7:43 AM
Quote - Here's demonstration. Depth mapped lights, with shadow maps at 1024, min bias back up to the default of 0.8.
With min bias set that high, it is likely that the lip geometry just isn't casting a shadow there any more.
Quote - It is not physically correct.
Poser's shadows are not anything close to physically correct even under the absolute best circumstances.
Do you have a 100% spotlight shining directly into the character's face, maybe 1 foot above the character's head? If not, where are your lights (screenshot would be nice)?
IsaoShi posted Sat, 15 August 2009 at 9:17 AM
Well, it may be no consolation, but I've just done some testing with base V4.2, in Poser Pro. Exactly the same results as you are getting. I've always used RT shadows, but I've just never noticed this before with my own lighting.
But I don't really attempt close-up realistic portraits; I find it just too difficult with Poser. At best it's a complex and time-consuming mixture of different techniques, and at worst an unsatisfactory compromise between conflicting needs.
In my tests, reducing the shadow min bias to 0.05 eliminated the problem with the lips, but introduced artifacts elsewhere on the face, particularly around the eyes.
what I should be."
Murakami)
bagginsbill posted Sat, 15 August 2009 at 11:40 AM
The point at which you guys are at here is where I was a while back, quite a few times. My expectations were occasionally violated - I see stuff I don't expect. My mental mental model suggests what should happen instead, and my model is wrong, but I persist in believing it is the software that is wrong.
I have always found success in correcting my mental model, my understanding of the situation. Usually this requires getting back to basics - and NOT rendering complicated multi-light scenarios with a high polygon figure.
The most important tools we have in Poser are the primitives. No joke. Not for creating scenes, but for becoming an expert at shaders and lighting, the primitives are worth $1000, yet we get them for free.
Let me show you how I understand what happens in a pair of lips, with the kind of lighting you're using.
This will take a few postings, and I'm doing the work in real time.
bagginsbill posted Sat, 15 August 2009 at 11:45 AM
The light is angled at 45 degrees elevation.
Observe how the bottom of the cylinder is black. This is not technically a shadow, because that surface is pointing away from the light. It is black because it isn't facing the light at all.
I say that is not a shadow because it will stay black no matter what else I do in the scene with other props, and also because shadows are not even turned on.
bagginsbill posted Sat, 15 August 2009 at 11:48 AM
What is the luminance of the ground? Zero - nada, black.
Hmmm. A surface parallel to the light source is black. Add that to our mental model.
Well I suppose that the very top and bottom of this cylinder, where the normals are straight up and down, are also black.
bagginsbill posted Sat, 15 August 2009 at 11:50 AM
bagginsbill posted Sat, 15 August 2009 at 11:51 AM
Yep.
bagginsbill posted Sat, 15 August 2009 at 11:54 AM
bagginsbill posted Sat, 15 August 2009 at 11:55 AM
bagginsbill posted Sat, 15 August 2009 at 11:56 AM
bagginsbill posted Sat, 15 August 2009 at 11:57 AM
So, now we understand this geometry and a directional light source - you cannot light the crevice at all with a directional light source. All you can do is increase the blackness, you can never decrease it. It is a simple fact of the geometry.
Let's tackle IBL next.
IsaoShi posted Sat, 15 August 2009 at 12:00 PM
(Following...)
what I should be."
Murakami)
bagginsbill posted Sat, 15 August 2009 at 12:01 PM
No AO is enabled. Observe how upward facing parts of cylinders reflect the IBL ceiling, while downward facing parts reflect the IBL floor.
The crevice is lit well, but wrong.
bagginsbill posted Sat, 15 August 2009 at 12:04 PM
So we usually want to adjust the ray bias as small as possible until we get all the detail of the scene without introducing artifacts.
bagginsbill posted Sat, 15 August 2009 at 12:05 PM
bagginsbill posted Sat, 15 August 2009 at 12:07 PM
bagginsbill posted Sat, 15 August 2009 at 12:09 PM
You can probably notice by now that we're heading for a totally black crevice.
This, despite the fact that the AO strength is .7, not 1.0. We'll investigate that later.
bagginsbill posted Sat, 15 August 2009 at 12:11 PM
But I can keep going here with ray bias in Poser 8.
bagginsbill posted Sat, 15 August 2009 at 12:12 PM
bagginsbill posted Sat, 15 August 2009 at 12:15 PM
Everybody with me?
For this type of crevice, a directional light colors it black, and so does IBL+AO.
Any combination of the two will still be black.
manoloz posted Sat, 15 August 2009 at 12:16 PM
This discussion reminds me of exterior architectural renders, where people wonder why all the interiors beyond the windows look black or very dark. It's how things are, but the brain "thinks" it should look just as lit as the exterior.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
bagginsbill posted Sat, 15 August 2009 at 12:17 PM
What changes? A theory might be the intensity of the mid-point of the shadow gradient is affected by "strength", not the most or least occluded, but what is half-occluded. !!!!
bagginsbill posted Sat, 15 August 2009 at 12:21 PM
I conclude that there is no way to get any light into the point of contact if AO is turned on and properly configured to operate all the way into the deepest part of the crack.
In fact, from my understanding of physics, this is correct behavior. In this geometrical situation, no light can reach the point of contact between the two cylinders. Very small amounts can reach very close, but the point of contact gets no direct or bounced light.
Real lips have SSS, so the light can reach the point of contact from under the surface, entering on the front, not the point of contact.
This is why we need SSS.
I could continue this experiment with IDL instead of IBL+AO, but I suspect it will result in the same. There is no direct way to get light into the crevice.
My wife insists I must go work for her now. Hehehe.
Believable3D posted Sat, 15 August 2009 at 12:49 PM
Quote - > Quote - Here's demonstration. Depth mapped lights, with shadow maps at 1024, min bias back up to the default of 0.8.
I think you're missing the point. I was showing that even at lower quality settings, the DM shadow is better than the RT shadow on this point, until I get the RT settings way down in the Min Bias. I can set the Min Bias on the DM wherever I bloody want - the DM will never ever ever make a blotch like that.
Quote - > Quote - It is not physically correct.
I was responding to ice-boy's insinuation that the ugly black mark was correct.
Pardon my frustration, but how many times do I have to say this? I have these results with a huge variety of angles. I showed several with the spotlights directly in front of the face. Not 1 foot above. Directly in front. Others, with various angles. (I can't show screen shots now, because I've changed the scene for every test. I'd have to recreate everything.)
Bagginsbill, your tests are interesting - but other than some of the weird things that AO is doing (perhaps because I don't fully understand AO) - and as you can see from the thread, I shut AO off first in the render settings, then in the materials but got the same problem - but as I say, other than some of the things AO is doing, your results are pretty much what I would expect. They are not the same thing as what is going on with my renders at the lips. Sure, the black is very black. That is not the issue. In every case, you're showing renders where there is a transition. Mine is a felt marker-like line, AO or no AO. That cannot be right and is impossible to be right. What you're showing is that the point of contact is completely black. But the point of contact between upper and lower lip is not 1/4"-1/2" thick. You can reference any photograph or mirror you want. You'll never see this, ever.
Moreover, my problem results are not reproduced by DM. Okay, poorer quality setup; fine. They're also not reproduced by RT at .05 settings. They're not reproduced by DAZ Studio with raytracing.
This isn't simply a violation of an erroneous mental preconception. It's a bad render.
My solution is simple. I keep the Min Bias much lower (hoping the other artifacting doesn't get too bad... I think I could probably get away with a 1 setting if necessary). But it's frustrating that I don't know a way to set up the default new light with my preferred settings. It's easy to overlook changing stuff like that until you've already rendered, plus, it's just a PITA.
______________
pjz99 posted Sat, 15 August 2009 at 1:13 PM
I may have greatly misunderstood Bagginsbill's posts, but they appear to boil down to, "It's a shadow." The ones where he's demonstrating AO behavior don't have to do with your specific complaint, which is about raytraced shadows - which he covered here:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2779249&page=2#message_3501830
Believable3D posted Sat, 15 August 2009 at 1:16 PM
Thanks. I understand his observations completely. But he's not reproducing what's happening. (And anyway, he has the light source above the objects there.) And as I said again, were it accurate, reducing Min Bias to .05 would (EDIT: would NOT) make it pretty much go away.
______________
kobaltkween posted Sat, 15 August 2009 at 7:41 PM
sorry, but i don't see the problem myself.
http://seedmagazine.com/images/uploads/attractive_article.jpg
http://img1.ak.crunchyroll.com/i/spire3/b244c4602bfe518343314db046afffef1224361421_full.jpg
depth-mapped shadows are just wrong, and with a small map size (especially without out zooming) they really don't shadow crevices on a face properly. even 1024 wouldn't necessarily be enough if the shadow cam covers a whole scene or even the whole figure. basically, you can't use them as your comparison, because physically, they're just completely wrong.
it sounds like what you're fighting with is spread or blur. what's your shadow blur on your raytraced shadows? when you use AO (if at all), what's your distance? imho, Poser's raytraced shadows do have a problem with being too differentially blurry. while they can blur nicely at a distance, the close shadows (like on the lips) are too sharp at almost any setting. but that's just to my eyes; i haven't actually done tests to match photos.
also, since you haven't mentioned it, i'm assuming these are all at the same blurring amount. even if it's not at 0, you might try turning it up.
the more important problem i've encountered with ray-traced shadows and blur is grain. stewer, is there any chance of getting light shadow sample control, the way we have for AO, in SP1 - or SP 3 or 4 for that matter - or Pro? if not, would it be possible (without revealing secrets or taking up tons of your time), to explain why this is difficult?
Believable3D posted Sat, 15 August 2009 at 10:36 PM
I find myself repeating myself.
I've had these problems with no blur.
I've had them with plenty of blur.
(Blur makes no sense whatsoever as an explanation, anyway, since there is no blur there, regardless - just a solid black [or red, in the case of the overexposed images] mark.)
I don't have them with DM lights no matter what the settings are. I don't have them in DAZ Studio with raytracing.
And yet again, if the hard ugly mark were right, it would still be there at .05 min bias on RT lights.
I find myself shocked that anyone can look at those images and think the lip mark is normal. No decent quality photo reference will give you that, never mind real life. Even the image you linked, although a very poor quality image (35 kb), isn't as extreme. You can still see a bit of a gradient as you approach the dark line, even though I'm certain the image has been postworked for high contrast (which would make the issue worse).
______________
manoloz posted Sun, 16 August 2009 at 12:15 AM
I prefer the dark shadow over the glowing nostrils in the shadow mapped version
What I would do without going into rocket science math nodes etc, would be:
Render two versions, one with shadow maps, one with raytraced shadows
And take the best part of both as postwork in the Gimp, Photoshop, etc etc.
Easier.
Faster.
Less frustrating.
So maybe it is perceptually wrong. Maybe it is physically-mathematically-etc correct. Who knows. But meanwhile, you get an image as you like it.
Visit my blog! :D
Believable3D posted Sun, 16 August 2009 at 12:42 AM
I'm already getting images as I like them, now, since following Stewer's advice to try .05 Min Bias. If I do get other artifacts, I'll experiment with how far I can edge it up and still have the lips acceptable. I did one angled render that suggested to me .1 may be okay, though not as good as .05.
______________
