Believable3D opened this issue on Aug 14, 2009 · 13 posts
Believable3D posted Fri, 14 August 2009 at 12:47 AM
There are all sorts of Python scripts listing things like content in a scene blah blah (see e.g. the Scripts > Print Info menu in P8).
Is there a script that will print material settings? a bit more complex, I suppose....
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
markschum posted Fri, 14 August 2009 at 1:44 AM
Did you want all the settings for all the nodes in all the materials ?
that gets really big :(
Believable3D posted Fri, 14 August 2009 at 2:09 AM
Yeah, I know. :) Ideally, though, I could specify to have the settings shown for just one material.
______________
PhilC posted Fri, 14 August 2009 at 4:41 AM
What exactly do you need it for?
In what format do you need the information?
How would it differ from just saving the material then opening the file in a text editor?
Believable3D posted Fri, 14 August 2009 at 9:17 AM
Heehee. Never thought of that. I'll do that and see what it looks like.
I want it, because I tinkered and tinkered with settings that were originally based on the AO version of VSS. I didn't think of saving the VSS prop rather than an MC on the figure, so it got detached. It's a convoluted story, but ultimately, what it boils down to is that I want to re-create a very close approximation of what I've got with a new iteration of the non-AO version of VSS, so I need to have a good look at the info that I can print out. Too easy to get lost with a visual method of comparing on the monitor, and anyway I don't have dual monitors at the moment.
______________
markschum posted Fri, 14 August 2009 at 10:17 AM
K, thats not to hard to do at all, probably take longer to make it pretty :)
markschum posted Fri, 14 August 2009 at 11:35 AM
There is ALL in the list of materials , which will list all materials,. Selecting a material will list only it.
Materials are from selected figure only at this stage. Requires Poser 7 for the dialog.
Believable3D posted Fri, 14 August 2009 at 9:08 PM
Wow, that's awesome! Thank you so much!!
______________
markschum posted Fri, 14 August 2009 at 10:21 PM
working on making it go to a formatted file rather than print, mainly cause I cant see how to print in python. :(
Is that close to what you wanted? I have added the node that connects to a parameter, so the inputs will show what node is attached.
I will post the completed script tomorrow .
Believable3D posted Sat, 15 August 2009 at 12:39 AM
Thanks so much for your work on this. I just printed it off (7 pages).
The ability to print directly isn't all that crucial, as it's no trouble to copy and paste into a new doc.
Nice work!
______________
markschum posted Sat, 15 August 2009 at 1:28 AM
yer welcome . thats actually a pretty simple script. :)
markschum posted Sat, 15 August 2009 at 9:51 AM
This prompts for what material you want , or ALL, and then prompts for the location and name of the save file. The heading is wrong on the save file screen but no way to change it .
The file is formatted text , and should view and print correctly from Wordpad.
Believable3D posted Sat, 15 August 2009 at 1:10 PM
Wow. Thanks again!
______________
