alpha117 opened this issue on Aug 14, 2009 · 4 posts
alpha117 posted Fri, 14 August 2009 at 3:38 PM
regards
grichter posted Fri, 14 August 2009 at 4:24 PM
I assume you have a spot light. If you do and not near Poser at the minute, on the property panel check how you have the fall off set, if at all. When I tried square fall off I got some orange spots like that. I think the option was linear and it solved it for the scene I had.
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
alpha117 posted Fri, 14 August 2009 at 4:35 PM
the light set i was using was the P8 ...studio broadlight ao
will have a look at it
thanks
Miss Nancy posted Fri, 14 August 2009 at 4:37 PM
there are some bad settings in render and/or render script: note that there's no occlusion.
this is a big difference between rendering a ball and some floating planes using the render script:
there's little context for realism in such a scene IMVHO, but here there is more.
