offrench opened this issue on Aug 20, 2009 · 11 posts
offrench posted Thu, 20 August 2009 at 11:49 AM
I am trying to animate a terrain and its materials in Vue 7.4 (latest build).
I am using the exact sequence detailed in the manual to animate materials:
I am using materials that contain dynamic ecosystems and noticed it does work when using simple non ecosystem materials.
Is there a workaround to animate ecosystems?
Is it a bug or is it simply impossible to animate ecosystems?
Fantasy pictures,
free 3d models, 3d tutorials
and
seamless textures on Virtual Lands.
Mazak posted Thu, 20 August 2009 at 12:24 PM
In your Options General Preferences tab click on Restore disabled messages. That should bring the dialog box back!
Mazak
Mazak posted Thu, 20 August 2009 at 12:31 PM
Mazak
offrench posted Thu, 20 August 2009 at 3:57 PM
Sorry, I did not made myself clear in the last sentence of my message.
In fact what I want to animate is the terrain material itself, not the material used in the ecosystem objects.
I want to have a terrain change materials :
Jungle -> cut down trees -> eroded grassland
I made other tries with Infinite 7.4 and 7.5 PLE.
It is possible to have material animation, but not if the first two materials include ecosystems. .
What I could get is a transition of this type:
normal material -> normal material -> ecosystem material
With any other combination, there is no animation and no material keyframe created.
If I start with an ecosystem material, there is no material animation possible at all.
I tried to trick it by first creating an animation with standard materials and then replacing them with ecosystems. This destroys the existing keyframes.
Fantasy pictures,
and
Mazak posted Thu, 20 August 2009 at 4:25 PM
Have you seen the animation example tutorial "Animated Eco-Population"? If I load the scene I can edit the underlying material flat gray and animate it. At last frame I change color to red and Vue asked for animation material and it did the correct color change.
You say you load a new material in editor, maybe here is the error?!? Change the material setting in existing material do not load a new material! A new material load break the animation process.
Mazak
nruddock posted Thu, 20 August 2009 at 5:19 PM
It seems clear from what you've tried, that Vue won't let you change EcoSystems.
I suspect the only solution is to split the animation into two segments and use a seperate copy of the scene file for each segment so that you can apply the two different EcoSystems.
offrench posted Fri, 21 August 2009 at 12:58 AM
Quote - Have you seen the animation example tutorial "Animated Eco-Population"?
Where did you find it? I have looked in the animations tutorials files and it does not seem to be there.
I have tried to animate some of the ecosystem properties (density) but to no avail. If I start with an ecosystem material, it is impossible to create a material animation keyframe.
Fantasy pictures,
and
Mazak posted Fri, 21 August 2009 at 2:55 AM
Mazak
Mazak posted Fri, 21 August 2009 at 3:04 AM
I you want, you can PM me with your e-mail address. The file has only 3MB in size.
Mazak
offrench posted Sat, 22 August 2009 at 1:21 PM
Hi, Mazak. No need to send me the file.
I have understood why it did not work for me. It is a 7.5 functionality as indicated on the product page, and it was not included in the 7.4 update (which is the one I use).
I will upgrade to 7.5 if need arises.
Thanks for your help.
Fantasy pictures,
and
Mazak posted Sat, 22 August 2009 at 1:29 PM
