Pret-a-3D opened this issue on Aug 22, 2009 · 7 posts
Pret-a-3D posted Sat, 22 August 2009 at 11:21 AM
Carrara 7.2
I'm trying to set up an eye light for The Girl. If I add a spot and set the "Restrict lighting to" option to "Only rEye" the light has no effect. I linked it to only light the whole figure and it works. If I restrict it to any sub-object, even head or neck it doesn't have any effect.
Anybody can confirm this?
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
MarkBremmer posted Sat, 22 August 2009 at 11:29 AM
This is because the selectors are actually for the bones, not the geometry. The work-around is to insert a target helper object and make it a child of the eye. You can also make the light a child of the eye as well so it follows the head if you reposed the characters. The final step is to use a Point-At behavior for the light and select the target helper object for the eye. Just adjust the spread of the to remain on the eye.
Mark
Pret-a-3D posted Sat, 22 August 2009 at 12:31 PM
Man, Mark, I've been following this forum and noticed how quickly you respond to the messages. This is quite incredible. Thanks.
I'm a bit surprised about the lights being linked to bones. What if I have a sphere and acube and I want to set separate lights for each object? This is kinda basic linking and I would not expected to have to have a right for every object in the scene. Just to be clear, I'm not concerned about keeping the light aimed at the eyes, that's fairly simple, I'm trying to avoid lighting the rest of the face. The target helper object would help me to aim it but then I will have to rely on a narrow beam and wide feathering of the cone to avoid lighting the eye socket. Am I correct?
Also, is there a way of setting up a light to only create specular effects without diffusion?
Thanks.
Paolo
Tw: @preta3d
G+:
The
MarkBremmer posted Sat, 22 August 2009 at 12:42 PM
Hi,
You just happened to catch me working today so I'm actually near the computer!
The link-to function will work with regular 3D geometry like spheres or cubes.
However, with figures, the figure is one big piece of 3D geometry - there is no eye or hand or head. All of the selectors that you see in the properties palette are the named bones that then influence the geometry. So, only in the case of figures, does selecting something like "eye" not work.
For tight eye lights, I'll usually create a mask and apply it to the spotlight to further shape the lighting.
For pure specular effect on eyes, it's usually better to simply create a custom texture map for the eye using a specific texture for the spec highlight. This can then also be dropped into the glow channel for a sparkle while on shadow sides.
Pret-a-3D posted Sat, 22 August 2009 at 12:50 PM
All good advices, thanks again Mark.
Paolo
Tw: @preta3d
G+:
The
GKDantas posted Sat, 22 August 2009 at 7:34 PM
Pret-a-3D posted Sat, 22 August 2009 at 7:39 PM
Yes, I tried it and it worked remarkably well, with very limited overhead.
Paolo
Tw: @preta3d
G+:
The
