Forum: Carrara
Subject: Magnetize clothing
Klebnor opened this issue on Aug 23, 2009 · 5 posts
Klebnor posted Sun, 23 August 2009 at 9:12 AM
Has anyone here successfully used the magnetize clothing morphs in Carrara?
If so, how do you use them, and do they work well?
Do the magnets need to be specific to the mesh, the morphs, or the clothing?
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device.  Beige horizontal case.  I don't display my unit.
Sueposer posted Sun, 23 August 2009 at 9:56 AM
I think the magnetize clothing morphs are for daz studio. Not needed for Carrara.
jt411 posted Sun, 23 August 2009 at 1:14 PM
The magnetize clothing poses are for both DS and Poser; they transfer Victoria 4's joint magnets to whatever conformed clothing you're using for better fitting/bending. I've always felt that the magnetize feature does more harm than good, so I always skip the step; I even goes far as to strip the ERC out of Poser CR2's.
In other words, you don't need to worry about it :)
Klebnor posted Sun, 23 August 2009 at 3:32 PM
Thanks to both of you.
Klebnor
adegner posted Sun, 30 August 2009 at 8:12 AM
Yes the magnitize clothing works in carrara especially for tight fitting clothing like any of the tight
stockings from hongyu.  On some items they don't seem to do much on others they are pretty
usefull.  Even works in poser 8.  Never tried em in DS3.
