Forum: Photoshop
Subject: looking for footprints of astronauts brushes or at least how to create these.
Bambam131 opened this issue on Aug 25, 2009 · 10 posts
Bambam131 posted Tue, 25 August 2009 at 8:31 AM
Is there an easy way to create boot prints of astronauts walking on the moon etc? I need these for both right and left boots and also a way to put these pointing in any direction. Any help would be most welcome.
Thanks,
David
retrocity posted Tue, 25 August 2009 at 10:27 PM
 your best bet is to have a wire frame of them done in a 3d program and add a texture to them -  this is the only way i am able to pull something like this off when i need the flexibility to rotate (change direction/orientation) the object...
other wise you'd have to make a brush for each foot, and each direction/variation...
hope it helps to point you in the right direction.
retrocity
Bambam131 posted Tue, 25 August 2009 at 10:41 PM
Retrocity, thanks for the info.
Regards,
David
goofygrape posted Wed, 26 August 2009 at 8:39 PM
If you mean when thy went to the moon,you will have to what as thy haven't gone yet.
goofygrape
Bambam131 posted Thu, 27 August 2009 at 5:20 AM
goofygrape, I am looking for help not stupid statements. Grow up!
bonestructure posted Thu, 27 August 2009 at 11:18 AM
Google image search, look for astronauts footprints, then make your own brushes out of the best you can find. The larger the image you can get, the better. Best advice I can think of. That's what I did when I needed to make some footprints in snow for a project. I didn't make a brush, I made a displacement map, but same principle.
Bambam131 posted Thu, 27 August 2009 at 2:44 PM
Hey Thanks bonestructure, I will try to see if that works.
All the best,
David
10thWay posted Sun, 30 August 2009 at 3:02 AM
Quote - Google image search, look for astronauts footprints, then make your own brushes out of the best you can find. The larger the image you can get, the better. Best advice I can think of. That's what I did when I needed to make some footprints in snow for a project. I didn't make a brush, I made a displacement map, but same principle.
That's the best advice I could give too rgarding creating the brush. As per chaging the direction of each footstep, here is the solution if you own a wacom intuos: get yourself a wacom 6D art marker pen. The marker pen will allow to rotate the direction of the brush just by rotating it in your hand. I hope this helps.
Booklet printing by 10th Way
Bambam131 posted Sun, 30 August 2009 at 8:32 AM
10thWay, thanks for the info..........
Cheers,
David
bonestructure posted Sun, 30 August 2009 at 9:33 AM
You might also google for astronaut's boots. Get a picture of the soles. I didn't stop to think that images of actual footprints on the moon might be somewhat hard to find. There's one famous print photo, I know, and may be others, but it may be easier to find images of the actual boot soles.
