Subject: Polygon count
A_Sunbeam opened this issue on Aug 26, 2009 ยท 7 posts
A_Sunbeam posted Wed, 26 August 2009 at 3:24 PM
How can I find out the polygon count for a Poser figure, (character or part of clothing)?
markschum posted Wed, 26 August 2009 at 3:54 PM
uv mapper will give you obj statistics if you load the obj.
I dont know if the poser grouping tool tells you how may polygons are in the set.
PhilC posted Wed, 26 August 2009 at 4:02 PM
The "Actor Stats" button in the Poser Tool Box will tell you.
http://www.philc.net/PTB_page2.php#geometryTools
May I ask why you need to know? Knowing I may be able to give a better answer.
A_Sunbeam posted Wed, 26 August 2009 at 4:17 PM
Quote - The "Actor Stats" button in the Poser Tool Box will tell you.
It was so I could check when using your Wardrobe Wizard.
Shaun
PhilC posted Wed, 26 August 2009 at 6:52 PM
Was it you that emailed me?
Try this, open the OBJ file in a text editor you may find that the polygon count is listed in the information at the top of the file.
Or open in a 3D modeling application, most will have some way of giving you information about the model. Or as markschum says use the statistics option in UV Mapper.
Jules53757 posted Thu, 27 August 2009 at 3:16 AM
Keep it simple. In Poser open Windows - Python Scripts then click on Print Info and then on Geom Stats. The window will show you all the information you'll need.
Ulli
A_Sunbeam posted Thu, 27 August 2009 at 2:04 PM
Quote - Keep it simple.
Thank you. Found the answer.
And thanks to the other posters who replied.
S
