Forum: Carrara
Subject: Bike build WIP
thomllama opened this issue on Aug 29, 2009 · 12 posts
thomllama posted Sat, 29 August 2009 at 11:43 AM
 bored in all the rain.. did the original vid just to make sure everything fit correctly, well actually fit incorrectly if that makes since... wanted some flaws that make it more real... anyway.. figured I'd share since it's pouring out from the tropical storm Danny....
http://ectrr.com/junkimages/3D_bikebuild/hanger.mov
Hexagon, Carrara, Sculptris, and recently Sketchup.
Xerxes0002 posted Sat, 29 August 2009 at 2:15 PM
nice work.. be safe from the storm
thomllama posted Sat, 29 August 2009 at 2:24 PM
 and an image along with another quick vid of many more parts all ready for assembly...[ectrr.com/junkimages/3D_bikebuild/assy1_2.mov](http://ectrr.com/junkimages/3D_bikebuild/assy1_2.mov)
pauljs75 posted Mon, 31 August 2009 at 6:53 PM
That's going to be a bit of work, but considering what there is so far, it should turn out nicely. I wonder how well this will work with any rigging and Sparrowhawke3D's wheels plugin and his tracks & chains plugin.
Barbequed Pixels?
thomllama posted Mon, 31 August 2009 at 8:01 PM
Quote - That's going to be a bit of work, but considering what there is so far, it should turn out nicely. I wonder how well this will work with any rigging and Sparrowhawke3D's wheels plugin and his tracks & chains plugin.
ya, it's certainly a learning experience!!!   The hard part is going to be the derailleur!
bwtr posted Mon, 31 August 2009 at 9:50 PM
You may find these bike tutes of value.
http://blueshexagon.brandycrest.com/MountainBike/
Brian
bwtr
pauljs75 posted Wed, 02 September 2009 at 12:45 PM
Any more progress? I know I'd save the deraileur and chain for last. (Lots of little bits, and you need the other geometry there in order to position them correctly.)
And are you doing traditional spoked wheels or composite? You'll probably want to google a bit on "bicycle wheel building" to do research if you're going with spoked wheels. (So you can figure out the count, cross pattern, and stagger.) Composite wheels are a lot easier to model in comparison.
Barbequed Pixels?
thomllama posted Wed, 02 September 2009 at 2:38 PM
Quote - Any more progress? I know I'd save the deraileur and chain for last. (Lots of little bits, and you need the other geometry there in order to position them correctly.)
I actually build my own wheels on my bikes so that's not so much an issue as the best way to lay it out in 3D
thomllama posted Wed, 02 September 2009 at 7:57 PM
latest...
thomllama posted Thu, 10 September 2009 at 10:39 PM
Attached Link: http://ectrr.com/Media/shifter2.mov
 and a fly around of the shift, did it just to check every thing.. handles are a tad thin but that's an easy fix.  check it out!!  :)
MarkBremmer posted Fri, 11 September 2009 at 8:16 AM
 Something tells me that you're enjoying working on this!  :D
thomllama posted Fri, 11 September 2009 at 10:50 AM
Quote -  Something tells me that you're enjoying working on this!  :D
isn't that kinda the point?  :)   but ya, fun combining my two passions, 3D and MT biking.
