Klebnor opened this issue on Aug 30, 2009 · 3 posts
Klebnor posted Sun, 30 August 2009 at 9:50 AM
Another quick question. From observation, it appears that easypose doesn't work in Carrara. There is some slight movement, but not the intended movement (twist all, bend after, etc.)
Is this something which isn't available in Carrara?
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
Sueposer posted Sun, 30 August 2009 at 10:06 AM
Those things do work, but you have to type in the numbers and they can be far greater than 1(forget the sliders!). Also, the root body part must be selected when you make the change. If you have some part midway up the chain selected, it all pops back to the numbers set on the starting link.
Klebnor posted Sun, 30 August 2009 at 12:01 PM
Thanks, Sue !
I'll try your methods.
Klebnor
