tomasball opened this issue on Sep 06, 2009 · 14 posts
tomasball posted Sun, 06 September 2009 at 9:17 AM
I created a terrain in Bryce, exported the grayscale map as a tiff, opened it in Photoshop, manipulated it, saved it, and applied it to my terrain back in Bryce. The resulting terrain renders all jagged and stairstepped compared to the original terrain. Why is that, and what can I do about it?
TheBryster posted Sun, 06 September 2009 at 9:22 AM
You can use the controls at the side of the terrain editor to smooth/raise/lower/manipulate your imported terrain.
Johny2 posted Sun, 06 September 2009 at 9:27 AM
Maybe before and after tiff files can make other member give better solution.
bobbystahr posted Sun, 06 September 2009 at 9:42 AM
Yes indeed..post your image in the thread...well a .jpg as a tiff won't post, so we can better assess the problem.. ...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
calyxa posted Sun, 06 September 2009 at 10:38 AM
sounds like photoshop saved it as only 8 bits per channel, where bryce terrains are 16 bits per channel - the 'stairstepping' is a dead give-away.
______________________________________________________________________________________
Check out my Elemental Hexagons deck, created with Photoshop, Bryce, MojoWorld, and Poser
Rayraz posted Sun, 06 September 2009 at 11:40 AM
I think calyxa is spot on here.
(_/)
dan whiteside posted Sun, 06 September 2009 at 12:20 PM
With Bryce 6.1 you can export 16-bit TIFF and PNG formats but you also need Photoshop CS3 to load and modify it. CS2 will load 16-bit but there are only a very few CS2 tools that work with them. Even CS3 doesn't support the whole tool set in 16-bit.
There are some problems with 16-bit PNG export from Bryce Mac - can't remember about the PC.
tomasball posted Mon, 07 September 2009 at 10:51 AM
tomasball posted Mon, 07 September 2009 at 10:53 AM
dan whiteside posted Mon, 07 September 2009 at 1:12 PM
jedswindells posted Mon, 07 September 2009 at 3:34 PM
I just run Paintshop along with Bryce and copy/paste from terrain editors' picture window to PS and back.
Now and then terrain editor won't accept the paste,I save from PS as .bmp and that seems to work fine!
Saves the fuss of exporting and is much quicker!Suppose this works with Photoshop too!
Cheers! Jed.
dan whiteside posted Mon, 07 September 2009 at 7:24 PM
Thanks Jed - didn't realize the clipboard did 16-bit copies.
jedswindells posted Mon, 07 September 2009 at 8:26 PM
No idea about 16-bit stuff?,seems to work for me!Never tred it for 'planetary size' too big and slow to work with!....works fine for more regular sizes.
Cheers! Jed.
artboy posted Thu, 10 September 2009 at 5:53 PM
I learned this in 3D Commune when it had many many masters of Bryce, that when you are in the (Terrain editor) and you have clicked the (Pictures) tab in the (Editing Tools) panel and then have clicked (Copy} your picture will be in the clip board. You can then open your pict in photoshop and after you have applied a filter or etc., and saved it as a bmp.You can then import it to Bryce as follows...Open the Terrain editor...In the (Editing Tools) panel, click the button on the left (Picture. note. this is not the Pictures under the tab Editing tools!) locate the file you have just saved and click it. You will then have a smooth and clean terrain. I work on a Mac. and my software is Bryce 6.1 and PS C3.
