markschum opened this issue on Sep 11, 2009 · 6 posts
markschum posted Fri, 11 September 2009 at 12:34 PM
Is there a way to set the preview window size from python.
poser.Scene().SetOutputRes(x,y) does not set the preview window.
also , set end frame for animations ? how ?
thanks
nruddock posted Fri, 11 September 2009 at 1:34 PM
Quote - Is there a way to set the preview window size from python.
I think it's possible for P8, but not earlier versions.
Quote - set end frame for animations ? how ?
I'm pretty sure that you can't change the number of frames directly via Python, but there may be a trick involving writing a temp file and then reading it.
markschum posted Fri, 11 September 2009 at 2:06 PM
ok, thanks
semidieu posted Fri, 11 September 2009 at 2:10 PM
SetOutputRes sets the rendering size, not the preview window. The only way I found to do it is to create a 'pose' file containing the doc size.
For the animations... I really don't know as I don't do them...
ockham posted Fri, 11 September 2009 at 9:40 PM
The temp PZ2 is still the only way to change frame count. I'm surprised they
haven't fixed that........
Here's the way to do it, in the form of a function that returns the same number
you asked for on success, or 0 on failure.
def FakeFrames(DesiredCount):
# Write a short PZ2 file forcing the desired number of
# frames; load it; delete it.
BasePathUncut=poser.AppLocation()
BasePath=BasePathUncut[:(-len('poser.exe'))]
DirName=os.path.join(BasePath, 'runtime', 'libraries', 'pose', 'fakes')
try:
os.mkdir(DirName)
except:
pass # ignore 'already exists' error
PZ2Name=os.path.join(DirName,'ztemp.pz2')
fpFake=open(PZ2Name,'wt')
if not fpFake: return 0
fpFake.write('{nversionnt{ntnumber 4.2nt}nmovieInfont{nt')
fpFake.write('numFrames %dnt}n}' % DesiredCount)
fpFake.close()
try:
scene.LoadLibraryPose(PZ2Name)
except:
return 0
os.remove(PZ2Name)
return DesiredCount
markschum posted Mon, 14 September 2009 at 11:45 PM
Thanks very much for that , it will be very useful.
I added some comment lines crediting you for it.
